Hi all,
I’ve 0.97.2 of HA on Synology docker and it happens in the last days it stops to work.
The last error is a custom component timeout ([homeassistant.core] Error doing job: Exception in callback) but could that cause a stop to the service?
On docker the service seems running, the port in listening, but the GUI doesn’t answer and no more logs are written. Seems frozen. I need to restart ot.
How to debug it?
Thanks, Simon
The standard advice is to disable all custom components and see if that helps.
You’ll also want to run a configuration check and look for errors.
Hi, thanks, I’ll starting with that!
Simon
Strange…this happened to me two times since updating to 0.97.2.
Same setup here: Synology (DS418play) with HA in Docker container.
HA just stops working.
Actually I’ve disabled external component and seems more stable, but I’ll wait some days more
Simon
