unfortunately my Home Assistant stopped working last night. I was running the previous version since 1 week without any problem.
Over night it stopped working. I’ve unpluged my raspi, but no sucess.
Are there any steps for solving such a problem. Or should I reinstall HA again an insert a snapshot?
I have a snapshot from beginning of january. Unfortunately I make every week a snapshot, but totally forgot to download it.
regards Tim
Hellis81
(Hellis81)
January 20, 2021, 10:56am
2
tom_l
January 20, 2021, 11:09am
3
Can you ping home assistant?
Did you have SSH enabled?
Have you tried connecting via that method?
You can probably get the snapshots of the SD card using a Linux PC or using Linux Reader (free) on a windows PC.
Also there are many options to create and copy off your snapshots automatically:
To a NAS: Samba Backup: Create and store snapshots on a Samba share
To Goggle Drive: Add-on: Home Assistant Google Drive Backup
To DropBox: Hass.io Add-on: Upload hassio snapshots to Dropbox
To NextCloud or S3: [New Addon] Snap-Shipper - Webdav and S3 backups (and probably other ways to later on)
SSH is disabled.
Going to tets if i can ping it tonight.
When I insert a snapshot, do i have to reconfigure all my tasmota switches ?
tom_l
January 20, 2021, 12:48pm
5
No, you shouldn’t have to do that. Restoring a snapshot should take you back to exactly like when the snapshot was taken.
m0wlheld
(Christoph Dahlen)
January 20, 2021, 3:17pm
6
Plug in a HDMI cable and connect to TV or monitor.
This is the screen when I plug the raspi to hdmi
Incan ping the raspi
But I can’t access with the browser or app
tom_l
January 20, 2021, 4:53pm
8
Well that’s good news. Home assistant is running.
First try this command:
ha core check
Also check the logs:
ha core logs
No need to login.
Core check is just running and running
Don´t give up. I just ran this on my system (RPI4) and its already taking 5 mins(and continuing), so just let it run.
Here is a list of commands you can use:
Completed now. Took around 7 minutes.
tom_l
January 20, 2021, 6:30pm
13
That looks like your database is corrupt.
Navigate to your config folder ( cd /config
) and rename the database with this command:
mv home-assistant_v2.db home-assistant_v2.db.old
Then this command:
ha core restart
Assuming that works we can fix your uptime sensor after that.
tom_l
January 20, 2021, 6:51pm
15
Great.
Now go to your config folder however you normally do (SAMBA?) and delete home-assistant_v2.db.old
Also edit your uptime sensor, remove the unit of measurement.
You’re my hero,
Everything is running again.
But what caused the broken db?
tom_l
January 21, 2021, 10:03am
17
Did you have a power outage?
Pulling the power before home assistant is shut down can corrupt the database, so can restoring from a snapshot, so can system updates (sometimes). It’s not very robust. I recommend MariaDB. That at least seems to be less prone to the third cause.
I’ve got another problem now
Everytime when I open my app now I get this notification.
m0wlheld
(Christoph Dahlen)
January 23, 2021, 4:43pm
20
I guess your API token got lost, too. Remove you device from the Mobile App integration and start over.
