Hi, I’m fairly new to this and this is the second time we lost the power/had to cut it due to works. The first time I ended up reinstalling everything and I was stupid enough for not having regular backups. Now I have been stuck in a loop after the second time. It’s fair to say that the WAF is getting quite low.
Those are the logs which keeps on looping for me for 3 hours now.
2024-12-20 20:03:39.687 INFO (MainThread) [supervisor.docker.interface] Updating image Package raspberrypi5-64-homeassistant · GitHub to Package raspberrypi5-64-homeassistant · GitHub
2024-12-20 20:03:39.687 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package raspberrypi5-64-homeassistant · GitHub with tag 2024.12.5.
2024-12-20 20:03:56.063 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.12.5: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.12.5/json: Not Found (“No such image: Package raspberrypi5-64-homeassistant · GitHub”)
2024-12-20 20:03:56.063 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
Any ideas what I could do?
