Hi there, I’m a HA user from a while now and since about 1 year I’m running it in a Proxmox VM on a NUC.
Here you can find my specs:
And my VM setup:
![Schermata 2021-04-19 alle 11.25.55](https://community-assets.home-assistant.io/original/3X/b/f/bfe9c2d8560a69384efa06c00d4eb6c6e5d65bad.png)
Since 3-4 months I’m experiencing random crashes every 1 or 2 days of operation of the VM. Web interface becomes unavailable or unresponsive as well as the CLI through Proxmox UI.
The following are some screenshots taken after the crashes:
(Note the CLI was responsive but the banner didn’t show up and the command didn’t work)
(This time the CLI didn’t respond to any input)
And one after a reboot:
Some other facts:
- I download the HassOS image, create the VM and import the image all manually because Whiskerz script had not always worked as intended;
- I did it several times;
- I recently formatted the SSD and reinstalled Proxmox and all the VMs from scratch. This solved only the MariaDB corruptions (?).
Please help me debugging this mess, I don’t know what else I can do.
Thank you in advance to the brave persons who would support me.
R
