Did a new fresh install of HA on my RPI4 4GB (with booting from fast m2 SSD-stick for OS) and the problem I’am getting is that after some time (sometimes after a couple of minutes) I can’t get access. Not from a browser (uses Mozilla, Chrome and Opera with Win11 and safari and chrome browser from ipados). I have to pull the powercord and put it back in to see it again.
I’m running:
In logfile I see some activity around 4-5 o’clock see below:
“2022-05-11 03:43:24 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry fe80::7297:41ff:fe91:f5f%3 for sensor
*** File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 335, in async_setup***
*** result = await component.async_setup_entry(hass, self)***
*** File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 240, in async_setup_entry***
*** return await component.async_setup_entry(entry)***
*** File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 157, in async_setup_entry***
*** raise ValueError(“Config entry has already been setup!”)***
ValueError: Config entry has already been setup!
2022-05-11 03:44:09 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 03:49:11 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 03:54:13 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 03:59:15 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:04:17 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:09:19 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:14:21 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:19:23 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:24:25 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:27:26 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 04:27:55 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 04:29:27 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:32:40 ERROR (Thread-18) [pychromecast.socket_client] [1e verdieping(192.168.2.52):32054] Error reading from socket.
2022-05-11 04:32:40 WARNING (Thread-18) [pychromecast.socket_client] [1e verdieping(192.168.2.52):32054] Error communicating with socket, resetting connection
2022-05-11 04:32:40 ERROR (Thread-18) [pychromecast.socket_client] [1e verdieping(192.168.2.52):32054] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.2.52’, 32054)), retrying in 5.0s
2022-05-11 04:33:10 WARNING (Thread-17) [pychromecast.socket_client] [Google Home Bram(192.168.2.52):8009] Heartbeat timeout, resetting connection
2022-05-11 04:33:17 ERROR (Thread-17) [pychromecast.socket_client] [Google Home Bram(192.168.2.52):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.2.52’, 8009)), retrying in 5.0s
2022-05-11 04:34:29 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:39:32 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:41:51 WARNING (Thread-11) [pychromecast.socket_client] [Google Home Woonkamer(192.168.2.45):8009] Heartbeat timeout, resetting connection
2022-05-11 04:41:58 ERROR (Thread-11) [pychromecast.socket_client] [Google Home Woonkamer(192.168.2.45):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.2.45’, 8009)), retrying in 5.0s
2022-05-11 04:44:34 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:49:56 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 04:50:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 04:54:39 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 04:59:41 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 05:07:55 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:08:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:08:56 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:09:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:09:46 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 05:09:56 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:10:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:14:48 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 05:14:55 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:15:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:16:55 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 05:17:25 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-05-11 09:34:39 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 09:34:39 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 09:34:39 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration genius_lyrics which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 09:34:39 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration apsystems_ecur which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 09:34:39 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration nest_protect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-11 09:34:41 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-05-11 09:34:41 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=21 from 2022-05-10 20:46:52.581977)
2022-05-11 09:34:47 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 09:34:54 DEBUG (SyncWorker_3) [homeassistant.components.rfxtrx] Using modes: ac,arc,lighting4,x10
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Send: 0x0d 0x00 0x00 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x2b 0x0a 0x0e 0x2f 0x00 0x01 0x03 0x29 0x06 0x70 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x03 0x53 0x29 0x08 0x00 0x07 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Recv: 0x14 0x01 0x00 0x00 0x03 0x53 0x2b 0x08 0x00 0x07 0x00 0x01 0x03 0x29 0x06 0x71 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x2b 0x08 0x00 0x07 0x00 0x01 0x03 0x29 0x06 0x71 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Status: Status [subtype=433.92MHz, firmware=43, output_power=41, devices=[‘ac’, ‘arc’, ‘lighting4’, ‘x10’]]
2022-05-11 09:34:54 DEBUG (Thread-3) [RFXtrx] Send: 0x0d 0x00 0x00 0x03 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2022-05-11 09:34:55 DEBUG (Thread-3) [RFXtrx] Recv: 0x14 0x01 0x07 0x03 0x07 0x43 0x6f 0x70 0x79 0x72 0x69 0x67 0x68 0x74 0x20 0x52 0x46 0x58 0x43 0x4f 0x4d
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-05-11 09:35:03 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-05-11 09:35:04 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-05-11 09:35:04 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2022-05-11 09:35:04 WARNING (MainThread) [homeassistant.components.update] Setup of update platform hassio is taking over 10 seconds.
2022-05-11 09:35:07 WARNING (MainThread) [coap] Received Type.ACK from <aiocoap.transports.tinydtls.DTLSClientConnection object at 0x7f8787a0d0>, but could not match it to a running exchange.
2022-05-11 09:35:09 WARNING (MainThread) [homeassistant.components.heos] 192.168.2.147 is not logged in to a HEOS account and will be unable to retrieve HEOS favorites: Use the ‘heos.sign_in’ service to sign-in to a HEOS account
2022-05-11 09:35:11 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can’t connect to ESPHome API for co2-woonkamer @ 192.168.2.191: Error connecting to (‘192.168.2.191’, 6053): [Errno 113] Connect call failed (‘192.168.2.191’, 6053)
2022-05-11 09:35:11 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can’t connect to ESPHome API for oled-woonkamer @ 192.168.2.15: Error connecting to (‘192.168.2.15’, 6053): [Errno 113] Connect call failed (‘192.168.2.15’, 6053)
2022-05-11 09:35:15 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe8f:9e5b%3’ for upnp integration not ready yet: (“Cannot connect to host 2a02:a442:ddae:1:7297:41ff:fe8f:9e5d:45725 ssl:default [Connect call failed (‘2a02:a442:ddae:1:7297:41ff:fe8f:9e5d’, 45725, 0, 0)]”, None); Retrying in background
2022-05-11 09:35:18 WARNING (MainThread) [homeassistant.components.synology_dsm.common] Connection error during update, fallback by reloading the entry
2022-05-11 09:35:18 WARNING (MainThread) [zigpy_znp.zigbee.application] Your network is using the insecure Zigbee2MQTT network key!
2022-05-11 09:35:24 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘fe80::7297:41ff:fe91:f5f%3’ for upnp integration not ready yet: (’’, None); Retrying in background
2022-05-11 09:35:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
2022-05-11 09:36:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
2022-05-11 09:37:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
2022-05-11 09:38:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
2022-05-11 09:39:49 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 - moving forward
2022-05-11 09:39:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
2022-05-11 09:40:03 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh: Container addon_core_ssh is not running
2022-05-11 09:40:56 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm”
Does anyone now whats going on? I now spend 3 days of installing, testing, reinstalling, testing, and so on. And yes not everything is configured yet
