hello friends.
I am running HA in RP3plus 32GB sd card.
I have 5 generic cameras installed in my Lovelace.
the HA stops suddenly with no reasons lastly and I can’t access it anymore.
do you think its because of the cameras? if yes what should I fix to use the 5 cameras with HS safely?
do you think using RP4 4gb with 64SSD is a good idea?
I am using it in the cabinet so I need the size to be small as much as I can.
thank you very much for your help in advance
