I usually install portainer side-by-side with HA Supervised just because I can monitor my HA in case it hit some problem. I just realize it on the latest HA portainer caused a problem for HA Supervised and make it unsupported. Does portainer create a problem for HA Supervised?
Is there a fixed?
Also I’m getting this error and unsure what need to be fixed
any chances you know the 2nd error message?
tom_l
October 26, 2021, 7:00am
4
Nope. There is an issue open though:
opened 02:52PM - 25 Oct 21 UTC
bug
### Describe the issue you are experiencing
I've upgraded to 2021.10.6 f… rom 2021.10.0, and now the following error is shown in the Supervisor log:
21-10-25 16:44:03 ERROR (MainThread) [supervisor.utils.dbus] No Set attribute Diagnostics for io.hass.os
21-10-25 16:44:03 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-62' coro=<DBus.set_property() done, defined at /usr/src/supervisor/supervisor/utils/dbus.py:185> exception=DBusFatalError()>
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 190, in set_property
return (await self.call_dbus(DBUS_METHOD_SET, interface, name, value))[0]
IndexError: list index out of range
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 193, in set_property
raise DBusFatalError() from err
supervisor.exceptions.DBusFatalError
### What is the used version of the Supervisor?
2021.10.6
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### What is the version of your installed operating system?
Home Assistant OS 6.5
### What version of Home Assistant Core is installed?
2021.10.6
### Steps to reproduce the issue
Upgrade to 2021.10.6, on HAOS 6.5, running on a Proxmox 7 server as a VM.
### Anything in the Supervisor logs that might be useful for us?
```txt
### Additional information
_No response_
