HA supervised firt start problem
I am trying to install HA supervised on a PC.
I am getting error at the below.
[supervisor.hardware.monitor] Not privileged to run udev monitor!
I tried to install HA from article below.
Also I tried to solve the problem via supervisor running unconfined (w/o apparmor profile) after reboot THEN w/ insufficient perms to monitor udev after recreate · Issue #4839 · home-assistant/supervisor · GitHub
Has anyone got any idea?
Thank you to all…
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Setting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.11.2
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
**[u][supervisor.hardware.monitor] Not privileged to run udev monitor![/u]**
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.os.manager] No Home Assistant Operating System found
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
[supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - privileged
[__main__] Running Supervisor
[supervisor.core] System is running in an unhealthy state and needs manual intervention!
[supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.core] Supervisor reboot detected
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.0
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.11.0.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.jobs] 'OSManager.reload' blocked from execution, no Home Assistant OS available
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.manager] Host information reload completed
Hi, welcome to the forum!
Do you really want/need Debian underneath your HA?
If not, you could install HAOS directly on your system.
thankyou for your kind answer.
no i dont realy need it… i will try as soon as possible.
If not really needed, HAOS will give you a much better experience, less hassle and you don’t need to maintain the OS separately from HA.
OTOH: if you would have installed Debian as OS, you could run other things as well on the same system but with HAOS there are also a lot of options to run services on top of it.
Alternatively you can run a hypervisor like QEMU and then install HAOS in that as a VM.
This will separate the HAOS from the Debian OS and thereby also separate the requirements.
