Able to run HA supervised with this setup:
- Xiaomi Note 8 ginkgo
- kernel with additional stuff for docker
(check your config https://github.com/moby/moby/raw/master/contrib/check-config.sh) - Drodian 12 OS (debian 12 variation)
- Docker on btrfs (because
overlayfs can’t be used on top of overlayfs) Use the BTRFS storage driver | Docker Documentation - Alpine container with --privileged --network=host, entry point- init
- HA in alpine container was installed with this guide GitHub - kuba2k2/alpine-home-assistant: Home Assistant Supervised on Alpine Linux
If you can’t install addons due “no connection”
ha network reload
I compiled kernel with ch341 drivers, but additional command required to have /dev/ttyUSB0
mknod /dev/ttyUSB0 c 188 0
HA core in docker container in termux (Android 13, kernel with additional cgroups, namespaces etc)
I don’t know if it’s possible to run HA supervised on Android without systemd. Later will try.
