HA Supervised - Random Freezups
RPI 4b, 8Gig RAM, running on a 1TB SSD (no MIcroSD card). System ‘freezes up’ once every 1 - 3 days.
Below is a copy of my syslog when the freeze takes place and right after whe I am forced to reboot it (everything normal before and after).
Below that are my system specs. Any ideas?
Mar 22 12:03:45 kruse-pi homeassistant[587]: #033[32m2023-03-22 12:03:45.849 INFO (MainThread) [pywizlight.discovery] Discovered bulb 192.168.0.19 with MAC 444f8e9f14dc#033[0m
Mar 22 12:03:47 kruse-pi homeassistant[587]: #033[32m2023-03-22 12:03:47.688 INFO (MainThread) [aioambient] Sending packet PING data None#033[0m
Mar 22 12:03:47 kruse-pi homeassistant[587]: #033[32m2023-03-22 12:03:47.772 INFO (MainThread) [aioambient] Received packet PONG data None#033[0m
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-de8d80c757766d7c202f23ce2f95ba1e907fdb0e98373d552a35ec466bf77895-merged-etc-hosts.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-de8d80c757766d7c202f23ce2f95ba1e907fdb0e98373d552a35ec466bf77895-merged-etc-hostname.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-de8d80c757766d7c202f23ce2f95ba1e907fdb0e98373d552a35ec466bf77895-merged-etc-resolv.conf.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-de8d80c757766d7c202f23ce2f95ba1e907fdb0e98373d552a35ec466bf77895-merged-run-dbus.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-de8d80c757766d7c202f23ce2f95ba1e907fdb0e98373d552a35ec466bf77895-merged-config.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-run-dbus.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-etc-machine\x2did.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-data.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-etc-hosts.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-etc-hostname.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-etc-resolv.conf.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-run-udev.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-run-systemd\x2djournal\x2dgatewayd.sock.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-run-os.mount: Succeeded.
Mar 22 12:03:49 kruse-pi systemd[1]: var-lib-docker-overlay2-0ef24b717dee5df03a5f7d5f9a6fda3c61bf6e795d4551a811955a52d55e5dff-merged-run-docker.sock.mount: Succeeded.
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] Linux version 5.10.0-21-arm64 ([email protected]) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.162-1 (2023-01-21)
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] efi: UEFI not found.
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x0000000037000000, size 64 MiB
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] NUMA: No NUMA configuration found
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
Mar 22 11:42:11 kruse-pi kernel: [    0.000000] NUMA: NODE_DATA [mem 0x1ff017b00-0x1ff019fff]
System Information
version core-2023.3.5
installation_type Home Assistant Supervised
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.10
os_name Linux
os_version 5.10.0-21-arm64
arch aarch64
timezone America/New_York
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.31.0
Stage running
Available Repositories 1316
Downloaded Repositories 22
AccuWeather
can_reach_server ok
remaining_requests 23
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Debian GNU/Linux 11 (bullseye)
update_channel stable
supervisor_version supervisor-2023.03.1
agent_version 1.4.1
docker_version 23.0.1
disk_total 915.4 GB
disk_used 18.0 GB
healthy true
supported true
supervisor_api ok
version_api ok
installed_addons AppDaemon (0.11.0), Core DNS Override (0.1.1), Duck DNS (1.15.0), File editor (5.5.0), Home Assistant Google Drive Backup (0.110.1), Log Viewer (0.14.0), Mosquitto broker (6.1.3), Samba share (10.0.0), Terminal & SSH (9.6.1), AdGuard Home (4.8.3)
Dashboards
dashboards 5
resources 15
views 29
mode storage
Recorder
oldest_recorder_run February 20, 2023 at 10:25 PM
current_recorder_run March 22, 2023 at 1:36 PM
estimated_db_size 1882.71 MiB
database_engine sqlite
database_version 3.38.5
