I just did a fresh install of HA supervisor and want to restore my quite simple Core backup, as I want to use the addons for Zigbee2MQTT.
Every time I try to restore the backup, HA crashes and I’ve no easy way to fix it without reinstalling HA again (since there’s no home-assistant.service running).
Is the supervisor version incapable of restoring a Core backup?
Jul 08 20:39:08 OrdroidN2Plus homeassistant[10219]: 2024/07/08 18:39:08 Start mDNS broadcast
Jul 08 20:39:08 OrdroidN2Plus homeassistant[10219]: 2024/07/08 18:39:08 Publish http://192.168.1.3:8123 to _home-assistant._tcp
Jul 08 20:39:08 OrdroidN2Plus homeassistant[10219]: 2024/07/08 18:39:08 Start webserver on http://0.0.0.0:8123
Jul 08 20:39:08 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:08.867 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/odroid-n2-homeassistant with version landingpage
Jul 08 20:39:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:09.925 WARNING (MainThread) [supervisor.resolution.evaluations.base] Docker cgroup version 2 is not supported! {'1'} (more-info: https://www.home-assistant.io/more-info/unsupported/cgroup_version)
Jul 08 20:39:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:09.947 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
Jul 08 20:39:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:09.948 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage to ghcr.io/home-assistant/odroid-n2-homeassistant:2024.7.1
Jul 08 20:39:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:09.948 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2024.7.1.
Jul 08 20:39:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:39:09.950 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
Jul 08 20:43:50 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:43:50.104 INFO (SyncWorker_8) [supervisor.docker.manager] Stopping homeassistant application
Jul 08 20:44:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:09.895 INFO (SyncWorker_8) [supervisor.docker.manager] Cleaning homeassistant application
Jul 08 20:44:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:09.954 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant docker now installed
Jul 08 20:44:09 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:09.974 INFO (MainThread) [supervisor.homeassistant.core] Starting Home Assistant
Jul 08 20:44:10 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:10.006 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
Jul 08 20:44:10 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:10.515 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/odroid-n2-homeassistant with version 2024.7.1
Jul 08 20:44:10 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:10.515 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner: starting
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner successfully started
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs: starting
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs successfully started
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init: starting
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init successfully started
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services: starting
Jul 08 20:44:10 OrdroidN2Plus homeassistant[10219]: services-up: info: copying legacy longrun home-assistant (no readiness notification)
Jul 08 20:44:11 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services successfully started
Jul 08 20:44:25 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:25.588 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Jul 08 20:44:25 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:25.594 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
Jul 08 20:44:27 OrdroidN2Plus dbus-daemon[1330]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.163' (uid=0 pid=12274 comm="python3 -m homeassistant --config /config ")
Jul 08 20:44:45 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:45.703 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
Jul 08 20:44:45 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:45.704 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
Jul 08 20:44:45 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:44:45.754 INFO (SyncWorker_7) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage']
Jul 08 20:46:35 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:35.577 INFO (MainThread) [supervisor.backups.manager] Restore 1a7d558d starting stage home_assistant
Jul 08 20:46:35 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:35.597 INFO (SyncWorker_8) [supervisor.docker.manager] Stopping homeassistant application
Jul 08 20:46:35 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services: stopping
Jul 08 20:46:46 OrdroidN2Plus homeassistant[10219]: Unable to find configuration. Creating default one in /config
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: [18:46:48] INFO: Home Assistant Core finish process exit code 0
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: [18:46:48] INFO: Home Assistant Core service shutdown
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services successfully stopped
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init: stopping
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init successfully stopped
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs: stopping
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs successfully stopped
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner: stopping
Jul 08 20:46:48 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner successfully stopped
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.118 INFO (MainThread) [supervisor.homeassistant.module] Restore Home Assistant Core config folder
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.629 INFO (MainThread) [supervisor.homeassistant.module] Restore Home Assistant Core config folder done
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.731 INFO (MainThread) [supervisor.backups.manager] Restore 1a7d558d starting stage await_home_assistant_restart
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.745 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2024.4.3
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.746 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:2024.7.1 to ghcr.io/home-assistant/odroid-n2-homeassistant:2024.4.3
Jul 08 20:46:54 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:46:54.747 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2024.4.3.
Jul 08 20:52:05 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:05.318 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning homeassistant application
Jul 08 20:52:05 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:05.938 INFO (MainThread) [supervisor.homeassistant.core] Successfully started Home Assistant 2024.4.3
Jul 08 20:52:06 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:06.042 INFO (SyncWorker_6) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/odroid-n2-homeassistant:2024.7.1']
Jul 08 20:52:38 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:38.672 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed ('172.30.32.1', 8123)]
Jul 08 20:52:38 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:38.683 INFO (MainThread) [supervisor.backups.manager] Restore 1a7d558d starting stage check_home_assistant
Jul 08 20:52:38 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:38.793 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
Jul 08 20:52:40 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:40.233 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/odroid-n2-homeassistant with version 2024.4.3
Jul 08 20:52:40 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:40.234 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner: starting
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner successfully started
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs: starting
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs successfully started
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init: starting
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init successfully started
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services: starting
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: services-up: info: copying legacy longrun home-assistant (no readiness notification)
Jul 08 20:52:40 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services successfully started
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: Fatal Error: Unable to create library directory /config/deps: [Errno 17] File exists: '/config/deps'
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: [18:52:45] INFO: Home Assistant Core finish process exit code 1
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: [18:52:45] INFO: Home Assistant Core service shutdown
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services: stopping
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-services successfully stopped
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init: stopping
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service legacy-cont-init successfully stopped
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs: stopping
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service fix-attrs successfully stopped
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner: stopping
Jul 08 20:52:45 OrdroidN2Plus homeassistant[10219]: s6-rc: info: service s6rc-oneshot-runner successfully stopped
Jul 08 20:52:50 OrdroidN2Plus hassio_supervisor[10219]: 2024-07-08 20:52:50.254 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
