I ran into a problem with the Supervisor and the Add-on “Studio Code Server”.
If I try to start the addon, the logs state, that the Add-on is running:
Add-on Log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Studio Code Server
Fully featured Visual Studio Code (VSCode) experience integrated in the Home Assistant frontend.
Add-on version: 5.8.1
You are running the latest version of this add-on.
System: Home Assistant OS 10.3 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.7.2
Home Assistant Supervisor: 2023.07.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
[11:57:30] INFO: Configuring timezone (Europe/Berlin)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-code-server: starting
s6-rc: info: service init-code-server successfully started
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-mosquitto successfully started
s6-rc: info: service init-user successfully started
s6-rc: info: service code-server: starting
s6-rc: info: service code-server successfully started
s6-rc: info: service legacy-services: starting
[11:57:33] INFO: Starting code-server...
s6-rc: info: service legacy-services successfully started
[2023-07-19T09:57:35.225Z] info Wrote default config file to ~/.config/code-server/config.yaml
[2023-07-19T09:57:36.777Z] info code-server 4.14.1 5c199629305a0b935b4388b7db549f77eae82b5a
[2023-07-19T09:57:36.783Z] info Using user-data-dir /data/vscode
[2023-07-19T09:57:36.861Z] info Using config file ~/.config/code-server/config.yaml
[2023-07-19T09:57:36.861Z] info HTTP server listening on http://0.0.0.0:1337/
[2023-07-19T09:57:36.861Z] info - Authentication is disabled
[2023-07-19T09:57:36.861Z] info - Not serving HTTPS
[2023-07-19T09:57:36.862Z] info Session server listening on /data/vscode/code-server-ipc.sock
but I am not able to access the frontend, not via the sidebar nor via the Add-on page, both state, that I have to start the Add-on:
I tried to find help on the according github page https://github.com/hassio-addons/addon-vscode/issues/679
but since the add-on is running, there is nothing wrong with the add-on and this seems to be a Supervisor-problem:
only thing related in the supervisor log
23-07-19 12:34:55 WARNING (MainThread) [supervisor.addons.addon] a0d7b954_vscode is already running!
23-07-19 12:36:55 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Studio Code Server to start, took more then 120 seconds
Is there a way to update, re-install or force the Supervisor to access the Add-on? Anything else, I could try?
Thanks in advance!
