So this logic i need to put inside “hasp_plate01_p6_colorconfig.yaml” file? Or i can make a new file? And pun all new logic in that new file?
You can create a new file, copy the logic from an existing file, and modify as needed. Refer to my post above for some ideas on how to approach that.
I mean what we call 503:
https://professionisti.bticino.it/catalogo-prodotti/matix-placche-dimmer-prese-elettriche-e-altre-funzioni/
exactly what I’d like to do.
Well done thanks for sharing
Anyone using Ha Switchplate with existing Bush Jaeger switches? Looking for a 3d printed filling.
Hello
I am trying to get this to work with ONLY the alarm panel, but I am getting all sorts of issues, i.e. I cannot fathom it out! Does anyone have the automations/hdi file just for the alarm please? And how do I keep the alarm set after a reboot?
Cheers
Mark
Hello Cesare,
can you share the 3D project?
Thanks luma
Managed to add this to my wall
Used the 3d model of yours
After that i design my own case to go ontop, (to hide the screw)
The end of the project looks really awesome
Looks great! Are you UK based and are you powering this off the light switch?
if someone is looking for Logus90 style fitting into EU 68 mm diameter box
check:
https://easyeda.com/zdar/d1-power-board
Nice work.
You cut away the frame on the inside at the top and the bottom.
Do you have a picture with the Logus blanking plate (Blindabdeckung)?
Yes I had to cut out inner parts of the frame to fit LCD. For the sides I’m using 7.5 mm parts of blanking plate.
hello @luma been around year and four months plates are working like magic using, one thing which is still going against me in my case is power cycle some times it happens few times a day and i want them plates to wait 1 minute and 30 seconds to connect to known wifi, so as when power cycles my wifi also need a minute or so to boot up.
and i am not very skilled at arduino sketch let alone json so it will be great help if you can point me to which part should i change in sketch so it waits 1min 30 seconds after power start to connect to known wifi before it goes into 5 min AP mode
TIA
Edit :
attaching pictures of my custom Clip on Plate hardware for hidden screws fits into Indian 2gang standard back box & the custom made UI with home button like layout
BACK FITTING FRAME
Main Home Page
Curtain Page
Dimmer Control
Scenes Page
Light Toggles
Hello all
it is posibel to use this display instad of nexion display?
Short answer, no, that display will not work with this project.
That display has a different interface than the Nextion. You would need to write your own display driver and connect the required pins. The Nextion display uses serial RX/TX to communicate. The display you linked does not.
Hi guys, I’ve been strugling for some time with the newest version of hassio or should I call it HassOs ??
My system:
System: HassOS 2.12 (armv7 / raspberrypi3)
Home Assistant version: 0.99.3
Supervisor version: 189
In the past I tested my HASP, and managed to connect and play with my Nextion.
Can anyone confirm that using latest version of HassOS, with the MQTT Broker Addon (I installed all following https://www.home-assistant.io/addons/mosquitto/, and successfully run the test) HASP should work?.
I also tried, MQTT Broker addon on Hassio - Unable to connect to the broker . But I cannot manage my HASP to connect to the MQTT broker.
Kindly request if anyone can point some docs, anything else to test/verify… confirm that current Hasp configuration docs should works under the current HassOS version.
Update: edited the full design made it a 2 part version a frame and a facia and tried new materials Like wood & dupont corian (in white), using big CNC machines to get this completed and in the end used a laser to add a little logo sharing some pictures
All materials
Back Frame With Magnets
wood & corian
wood front (pending polishing)
@luma the project keeps on giving thank you so much
