scubieman
(scub man)
August 18, 2020, 3:03pm
1599
Trying to save new mqtt settings to haswitchplate. I am getting the following error. None of the settings are saving
Last reset: Fatal exception:0 flag:4 (SOFT_RESTART) epc1:0x00000000 epc2:0x00000000 epc3:0x00000000 excvaddr:0x00000000 depc:0x00000000
luma
August 18, 2020, 3:07pm
1600
What software are you using to flash the HASP?
luma
August 18, 2020, 3:12pm
1602
Not familiar with that tool, check to see if it has an option to clear EEPROM when flashing to do a full reset of your device.
scubieman
(scub man)
August 18, 2020, 3:13pm
1603
luma:
EEPROM
EDIT: I flashed with esp-home flasher vs tasmotizer and it works fine now.
it says âerase before flashingâ I could try like espeasyflasher or something?
luma
August 18, 2020, 3:21pm
1604
I just tried Tasmotizer and it does seem to work. What happens if you do a reset of the device, either by pulling the USB cable to cycle power, or hitting the reset button? Are you stuck in a boot loop? Can you post serial debug logs of this process?
edit: after a reboot my device was also unable to retain stored EEPROM settings, seems like Tasmotizer is doing something funky here. Guess thatâs not a good piece of software to use for HASP.
scubieman
(scub man)
August 18, 2020, 3:33pm
1605
See above, i got it working with different program. All is good here!!
scubieman
(scub man)
August 18, 2020, 5:06pm
1606
New question, Trying to pull value from HA, Not sure how to do this but great if you could help. The sensor is
sensor.dark_sky_apparent_temperature
service: mqtt.publish
topic: âhasp/plate01/command/p[2].b[6].txtâ
payload_template: â"{sensor.dark_sky_apparent_temperature }°"â
Tragos
(Tragos)
August 19, 2020, 9:17am
1607
- service: mqtt.publish
topic: 'hasp/plate01/command/p[2].b[6].txt'
payload_template: '"{{ states.sensor.dark_sky_apparent_temperature.state }}°"'
gazzaman2k
(Gareth Williams)
August 23, 2020, 3:23pm
1609
hi on page 6 there are 8 buttons what do they start from numberwise
i take its 4-11 im trying to fill in the 8 squares to turn each one into a toggle button
thanks
gazzaman2k
(Gareth Williams)
August 23, 2020, 5:28pm
1611
thanks luma finally got one in my finished lounge
for anyone who wants page 6 fully populated with 8 buttons copy my code below
# Automations for handling toggle state buttons on page 6
automation:
# Set font and text for toggle buttons on device connection
- alias: hasp_livingroom_p6_Buttons_2x4Init
- platform: state
entity_id: "binary_sensor.livingroom_connected"
to: "on"
- platform: homeassistant
event: start
# Set font and justification for the 8 buttons (b4-b11)
topic: "hasp/livingroom/command/json"
payload: '["p[6].b[4].font=0","p[6].b[5].font=0","p[6].b[6].font=0","p[6].b[7].font=0","p[6].b[8].font=0","p[6].b[9].font=0","p[6].b[10].font=0","p[6].b[11].font=0","p[6].b[4].xcen=2","p[6].b[5].xcen=2","p[6].b[6].xcen=2","p[6].b[7].xcen=2","p[6].b[8].xcen=2","p[6].b[9].xcen=2","p[6].b[10].xcen=2","p[6].b[11].xcen=2"]'
# Set text labels for the top 8 buttons (b4-b11)
payload: '["p[6].b[4].txt=\"LivingroomCurtains \"","p[6].b[5].txt=\"DiningroomCurtains \"","p[6].b[6].txt=\"Underfloor Fans \"","p[6].b[7].txt=\"Sun Shade \"","p[6].b[8].txt=\"Spotlights \"","p[6].b[9].txt=\"LEDS \"","p[6].b[10].txt=\"Lamps \"","p[6].b[11].txt=\"Fishtank \""]'
# Toggle light1 when p[6].b[4] pressed
- alias: hasp_livingroom_p6_ToggleLight1
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[4]"
payload: "ON"
- service: homeassistant.toggle
entity_id: switch.living_room_curtains
# Toggle light2 when p[6].b[5] pressed
- alias: hasp_livingroom_p6_ToggleLight2
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[5]"
payload: "ON"
entity_id: switch.diningroom_curtains
# Toggle light3 when p[6].b[6] pressed
- alias: hasp_livingroom_p6_ToggleLight3
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[6]"
payload: "ON"
entity_id: switch.underfloor_fans
# Toggle light4 when p[6].b[7] pressed
- alias: hasp_livingroom_p6_ToggleLight4
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[7]"
payload: "ON"
entity_id: switch.diningroomshade
# Toggle light5 when p[6].b[8] pressed
- alias: hasp_livingroom_p6_ToggleLight5
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[8]"
payload: "ON"
entity_id: light.spot_lights
# Toggle light6 when p[6].b[9] pressed
- alias: hasp_livingroom_p6_ToggleLight6
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[9]"
payload: "ON"
entity_id: light.ceiling_led
# Toggle light7 when p[6].b[10] pressed
- alias: hasp_livingroom_p6_ToggleLight7
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[10]"
payload: "ON"
entity_id: light.lamps
# Toggle light8 when p[6].b[11] pressed
- alias: hasp_livingroom_p6_ToggleLight8
- platform: mqtt
topic: "hasp/livingroom/state/p[6].b[11]"
payload: "ON"
entity_id: light.fishtank_light
# Toggle colors on p[6].b[4] when light1 changes
- alias: hasp_livingroom_p6_ToggleColor1
- platform: state
- platform: state
to: "on"
event: start
- platform: state
entity_id: input_number.hasp_livingroom_selectedbackgroundcolor
- platform: state
entity_id: input_number.hasp_livingroom_unselectedbackgroundcolor
- platform: state
entity_id: input_number.hasp_livingroom_selectedforegroundcolor
- platform: state
entity_id: input_number.hasp_livingroom_unselectedforegroundcolor
payload_template: >-
[{% if states('switch.living_room_curtains') == "on" -%}
"p[6].b[4].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[4].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[4].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[4].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[5] when light2 changes
- alias: hasp_livingroom_p6_ToggleColor2
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('switch.diningroom_curtains') == "on" -%}
"p[6].b[5].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[5].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[5].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[5].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[6] when light3 changes
- alias: hasp_livingroom_p6_ToggleColor3
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('switch.underfloor_fans') == "on" -%}
"p[6].b[6].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[6].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[6].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[6].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[7] when light4 changes
- alias: hasp_livingroom_p6_ToggleColor4
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('switch.diningroomshade') == "on" -%}
"p[6].b[7].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[7].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[7].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[7].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[8] when light5 changes
- alias: hasp_livingroom_p6_ToggleColor5
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('light.spot_lights') == "on" -%}
"p[6].b[8].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[8].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[8].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[8].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[9] when light6 changes
- alias: hasp_livingroom_p6_ToggleColor6
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('light.ceiling_led') == "on" -%}
"p[6].b[9].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[9].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[9].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[9].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[10] when light7 changes
- alias: hasp_livingroom_p6_ToggleColor7
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('light.lamps') == "on" -%}
"p[6].b[10].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[10].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[10].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[10].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
# Toggle colors on p[6].b[11] when light8 changes
- alias: hasp_livingroom_p6_ToggleColor8
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
- platform: state
- platform: state
[{% if states('light.fishtank_light') == "on" -%}
"p[6].b[11].bco={{ states('input_number.hasp_livingroom_selectedbackgroundcolor') | int }}","p[6].b[11].pco={{ states('input_number.hasp_livingroom_selectedforegroundcolor') | int }}"
{%- else -%}
"p[6].b[11].bco={{ states('input_number.hasp_livingroom_unselectedbackgroundcolor') | int }}","p[6].b[11].pco={{ states('input_number.hasp_livingroom_unselectedforegroundcolor') | int }}"
{%- endif %}]
great work as always
scubieman
(scub man)
August 27, 2020, 2:39pm
1612
Anybody have documention on the PIR sensor. I have one installed. Not sure what it does lol. Does it report back to HA? Does it turn screen off and on? I seen video where it scrolls or something with motion but not sure.
rlust
August 28, 2020, 5:54pm
1613
Since a recent HA update my HASwitch plates have been unavailable to HA. I am connect to MQTT and can connect to ESP. All of my automations are enabled, but never getting past initial Wifi connected screen. A
Any ideas?
gazzaman2k
(Gareth Williams)
August 28, 2020, 7:54pm
1614
does anyone have a sample page for the code for Page 11 Please and what should the file be name as?
hasp_devicename_p10_**********.yaml
thanks
luma
August 28, 2020, 9:51pm
1615
What happens if you move the active page slider in Home Assistant for this device? Does the device change pages?
If not, what exactly is being shown on the display?
luma
August 28, 2020, 9:53pm
1616
The filename kinda doesnât matter outside of the .yaml
bit. If you want to stick with existing convention, you could do hasp_devicename_p11_whatever.yaml
I havenât included any demo automations for page 11 as I didnât think of anything to stick in there. Thereâs just one button p[11].b[4]
which works like buttons on other pages, so you should be able to copy something from, say, page 1 to trigger a scene or whatever youâd like.
rlust
August 29, 2020, 3:31am
1617
Moving active slider does nothing. I have rebooted and unplugged devices and all that I get is,
Wifi Connected - IP address
MQTT Connected and mqtt IP
I have 4 devices and all show unavailable in HA.
I tried changing name of one device, and running new install script for device.
Still no change.
Thanks for ideas!!
luma
August 29, 2020, 3:08pm
1618
Any chance you could post a debug log from the device? If you have one connected to your PC via serial that will work, or you can enable telnet debug and telnet to the device.
