Yesterday I restarted HA and it took a lot of time to boot, saying that recorder is being started. Finally it boots but several integrations which relies in the recorder doesn’t work.
It’s in a hd, not an SD card.
I attach screenshots:
And log:
And log:
share the contents of your configuration.yaml.
There you are:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
recorder:
db_url: !secret mariadb_url
purge_keep_days: 20
commit_interval: 20
exclude:
domains:
- device_tracker
- remote
- script
- sun
- zone
- automation
- updater
- media_player
entity_globs:
- sensor.spiritu_*
- sensor.legrand_*
- binary_sensor.*_battery_low
- binary_sensor.*_tamper
- binary_sensor.*_update_available
- binary_sensor.*op8*
- binary_sensor.*op9pro
- binary_sensor.disk*
- binary_sensor.presencia_*
- number.presencia_*
- person.*
- sensor.*_battery
- sensor.*_linkquality
- sensor.*_raw
- sensor.*_update_state
- sensor.*op8*
- sensor.*op9pro
- sensor.disk*
- sensor.load_*
- sensor.lxc*
- sensor.memory_*
- sensor.node*
- sensor.panasonic_heat_pump_stats_*
- sensor.presencia_*
- sensor.qemu*
- sensor.rt_ax86u_*
- sensor.storage*
- sensor.weather_*
- sensor.fire_tablet_*
entities:
- sun.sun
- sensor.panasonic_heat_pump_main_compressor_freq
- sensor.fire_tablet_memoria_libre
event_types:
- call_service
influxdb:
host: !secret influxIP
port: 8086
api_version: 1
max_retries: 3
password: !secret influxdb_password
username: !secret influx user
database: !secret influx db
measurement_attr: unit_of_measurement
default_measurement: units
ssl: false
verify_ssl: false
tags:
source: HA
tags_attributes:
- friendly_name
- unit_of_measurement
exclude:
domains:
- automation
- alarm_control_panel
- button
- script
- camera
- device_tracker
- light
- remote
- scene
- sun
- zone
- updater
- media_player
entity_globs:
- sensor.f20t60a_*
- sensor.spiritu_*
- sensor.legrand_*
- person.*
- sensor.*_battery
- sensor.*_raw
- sensor.*op8*
- sensor.*op9pro
- sensor.disk*
- sensor.load_*
- sensor.lxc*
- sensor.memory_*
- sensor.node*
- sensor.qemu*
- sensor.rt_ax86u_*
- sensor.storage*
- sensor.weather_*
- sensor.medidor_calidad_de_aire*
- sensor.watchman_*
- sensor.medidor_calidad_piscina_*
- sensor.esphome_web_*
- sensor.nivel_deposito_de_agua_*
- number.nivel_deposito_de_agua_*
entities:
- sun.sun
- sensor.timbre_garaje_last_motion
- sensor.camara_ninos_last_motion
- sensor.angulo_solar
- sensor.amanecer
- sensor.sun_state
- sensor.day_night
- number.tapocam_diego_motion_detection_digital_sensitivity
- switch.patiodd_motion
- switch.patiodi_motion
- switch.patiotd_motion
- switch.patioti_motion
- binary_sensor.patioti_motion
- binary_sensor.patiotd_motion
- binary_sensor.patiodd_motion
- binary_sensor.patiodi_motion
- select.tapocam_diego_motion_detection
- binary_sensor.teclado_motion
- binary_sensor.teclado_garaje_motion
- binary_sensor.camara_helena_motion_2
- number.camara_helena_motion_duration
- binary_sensor.timbre_garaje_motion
- number.timbre_garaje_motion_duration
- switch.timbre_garaje_motion_detection
- switch.camara_ninos_motion_detection
- switch.camara_ninos_motion_warning
- select.camara_diego_motion_detectionp
- binary_sensor.camara_diego_cell_motion_detection
- number.camara_diego_motion_detection_digital_sensitivity
- binary_sensor.tapocam_diego_cell_motion_detection
- sun.sun
- automation.f20t60a
# para poder dividir este archivo en varios
group: !include groups.yaml
automation old: !include_dir_merge_list automation/
script: !include scripts.yaml
scene: !include scenes.yaml
cover: !include covers.yaml
input_number: !include input_numbers.yaml
timer: !include timers.yaml
sensor: !include sensor.yaml
switch: !include switches.yaml
template: !include template.yaml
light: !include lights.yaml
binary_sensor: !include binary_sensor.yaml
homeassistant:
# packages: !include_dir_merge_named packages/
customize: !include customize.yaml
allowlist_external_dirs:
- /tmp
logger:
default: warn
logs:
# log level for HA core
homeassistant.core: warn
frontend:
themes: !include_dir_merge_named themes
extra_module_url:
- /local/card-mod.js
- /local/community/custom-brand-icons/custom-brand-icons.js
##bot telegram
telegram_bot:
- platform: polling
api_key: !secret telegram_token
allowed_chat_ids: [!secret telegram_urgente, !secret telegram_no_urgente]
http:
use_x_forwarded_for: true
trusted_proxies:
# - 172.16.0.0/12
# - 127.0.0.1
- 172.30.33.0/24
- 192.168.0.4
# ip_ban_enabled: true
# login_attempts_threshold: 5
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
python_script:
powercalc:
utility_meter:
consumo_diario_aerotermia:
source: sensor.medidor_energia_aerotermia_power
cycle: daily
enchufe_navidad_energy:
source: sensor.enchufe_navidad_power_2
cycle: hourly
consumo_agua_horario:
name: "Consumo Agua - Horario"
source: sensor.esp_contador_de_agua_en_litros
cycle: hourly
consumo_agua_diario:
name: "Consumo Agua - Diario"
cycle: daily
consumo_agua_mensual:
name: "Consumo Agua - Mensual"
cycle: monthly
consumo_agua_anual:
name: "Consumo Agua - Anual"
cycle: yearly
# For Energy Cards
# For Solar Yield - Self use
# For Solar Yield - Self-Sufficiency
power_meter_consumption_energy_daily:
unique_id: power_meter_consumption_energy_daily
# friendly_name: 'power_meter_consumption - Energy daily'
source: sensor.power_meter_consumption
cycle: daily
power_meter_consumption_energy_weekly:
unique_id: power_meter_consumption_energy_weekly
# friendly_name: 'power_meter_consumption - Energy weekly'
cycle: weekly
power_meter_consumption_energy_monthly:
unique_id: power_meter_consumption_energy_monthly
# friendly_name: 'power_meter_consumption - Energy monthly'
cycle: monthly
power_meter_consumption_energy_yearly:
unique_id: power_meter_consumption_energy_yearly
# friendly_name: 'power_meter_consumption - Energy yearly'
cycle: yearly
# For Energy Cards
power_meter_exported_energy_daily:
unique_id: power_meter_exported_energy_daily
# friendly_name: 'power_meter_exported - Energy daily'
source: sensor.power_meter_exported
cycle: daily
power_meter_exported_energy_weekly:
unique_id: power_meter_exported_energy_weekly
# friendly_name: 'power_meter_exported - Energy weekly'
cycle: weekly
power_meter_exported_energy_monthly:
unique_id: power_meter_exported_energy_monthly
# friendly_name: 'power_meter_exported - Energy monthly'
cycle: monthly
power_meter_exported_energy_yearly:
unique_id: power_meter_exported_energy_yearly
# friendly_name: 'power_meter_exported - Energy yearly'
cycle: yearly
inverter_yield_weekly:
unique_id: inverter_yield_weekly
# friendly_name: ' inverter_yield - Energy weekly'
source: sensor.inverter_total_yield
cycle: weekly
inverter_yield_monthly:
unique_id: inverter_yield_monthly
# friendly_name: ' inverter_yield - Energy monthly'
cycle: monthly
inverter_yield_yearly:
unique_id: inverter_yield_yearly
# friendly_name: ' inverter_yield - Energy yearly'
cycle: yearly
house_consumption_energy_weekly:
unique_id: house_consumption_energy_weekly
# friendly_name: 'house_consumption - Energy weekly'
source: sensor.house_consumption_energy_total
cycle: weekly
house_consumption_energy_monthly:
unique_id: house_consumption_energy_monthly
# friendly_name: 'house_consumption - Energy monthly'
cycle: monthly
house_consumption_energy_yearly:
unique_id: house_consumption_energy_yearly
# friendly_name: 'house_consumption - Energy yearly'
cycle: yearly
solar_yield_daily:
unique_id: "solar_yield_daily"
# friendly_name: 'solar_yield - Energy daily'
source: sensor.solar_yield
cycle: daily
# PV Panels Yield without Inverter Input Correction
# - Only for diagnostic and only used in the diagnostic cards
solar_yield_without_correction_daily:
unique_id: "solar_yield_without_correction_daily"
# friendly_name: 'solar_yield without correction - Energy daily'
source: sensor.solar_yield_without_correction
cycle: daily
# Only for Calibration of sensor.solar_yield Correction
# - quarter-hourly
solar_yield_quarter_hourly:
unique_id: "solar_yield_quarter_hourly"
# friendly_name: 'solar_yield - Energy quarter-hourly'
cycle: quarter-hourly
inverter_yield_quarter_hourly:
unique_id: inverter_yield_quarter_hourly
# friendly_name: ' inverter_yield - Energy quarter-hourly'
# - hourly
solar_yield_hourly:
unique_id: "solar_yield_hourly"
# friendly_name: 'solar_yield - Energy hourly'
cycle: hourly
inverter_yield_hourly:
unique_id: inverter_yield_hourly
# friendly_name: ' inverter_yield - Energy hourly'
cycle: hourly
panel_custom:
- name: zigbee2mqtt
sidebar_title: Z2MQTT Garaje
sidebar_icon: mdi:zigbee
js_url: /api/hassio/app/entrypoint.js
url_path: 45df7312_zigbee2mqtt/ingress
embed_iframe: true
require_admin: true
config:
ingress: core_configurator
- name: automatizaciones
sidebar_title: Automatizaciones
sidebar_icon: mdi:cog-transfer
url_path: config/automation/dashboard
embed_iframe: true
require_admin: true
config:
- name: ourgroceries
sidebar_title: Lista de la compra
sidebar_icon: mdi:basket-check
url_path: todo/carrefour
embed_iframe: true
require_admin: true
config:
- name: dispositivos
sidebar_title: Dispositivos
sidebar_icon: mdi:devices
url_path: 'config/integrations/dashboard'
embed_iframe: true
require_admin: true
config:
mqtt:
- name: 'Airtag 1'
unique_id: mqtt_airtag_one
state_topic: 'btlescan/mypc/airtag_one'
value_template: '{{ value_json.present }}'
- name: 'Airtag 2'
unique_id: mqtt_airtag_two
state_topic: 'btlescan/mypc/airtag_two'
- name: 'Airtag 3'
unique_id: mqtt_airtag_three
Turns out it was something with mariadb lxc; rebooted it and everything started working fine.
