The Home Assistant node called Time or ha-time is used to get the alarm time from my Android phone. It syncs immediately, and displays the next alarm time under the node. But the problem is that it only outputs once per day, even if I set a new alarm later the same day.
This seems to be intended as per the node help:
Repeat Daily boolean
If selected the node will only use the time portion of the date string to schedule the node and will trigger at that time each day. Otherwise, the node will only trigger once at the given day and time.
Is there any way to fetch the next alarm time with this (or another) node? It clearly displays it under the node:
