Hello. I set up HA 2022.8 last month on an SSD. All was well until I tried to upgrade to 2022.9. It would seem like it updated, but will still be at the old version number. Today a second update was available for Core? I think? That installed OK. Then I tried 2022.9 again … It booted up to the 1st boot screen…like a fresh install. I did make backups, but didn’t realize I would need to download them. Is there a way to access backups stored on the SSD?
That would be like backing up your boot drive on the boot drive.
You would need to put the SSD on a Linux computer then look in the /backup directory. The .tar files are your backups. Copy these into your Home Assistant /backup directory (use sudo because root is the owner) and you should be able to restore your latest backup.
➜ / cd /backup
➜ /backup ls -al
total 24899348
drwxr-xr-x 2 root root 4096 Sep 19 17:08 .
drwxr-xr-x 1 root root 4096 Sep 18 08:39 ..
-rw-r--r-- 1 root root 248 Sep 19 00:27 .samba_backup.sensor
-rw-r--r-- 1 root root 819200 Sep 19 17:07 20789ac6.tar
-rw-r--r-- 1 root root 10240 Sep 11 23:00 3f5399de.tar
-rw-r--r-- 1 root root 15368529920 Sep 19 00:24 465ca1ab.tar
-rw-r--r-- 1 root root 819200 Sep 19 17:06 5efd7c18.tar
-rw-r--r-- 1 root root 119592960 Sep 11 23:02 904389d1.tar
-rw-r--r-- 1 root root 95457280 Sep 18 08:40 a5179347.tar
-rw-r--r-- 1 root root 111564800 Sep 19 17:08 aa0fd9a4.tar
-rw-r--r-- 1 root root 819200 Sep 7 12:46 ad8908db.tar
-rw-r--r-- 1 root root 141117440 Sep 7 15:52 b578a107.tar
-rw-r--r-- 1 root root 819200 Sep 7 12:45 cafc523e.tar
-rw-r--r-- 1 root root 10240 Sep 7 12:47 d42646b8.tar
-rw-r--r-- 1 root root 9657313280 Sep 7 15:48 f4c97081.tar
-rw-r--r-- 1 root root 10240 Sep 18 08:34 f70f3b2a.tar
