HA UI not rendering after reboot
Running regular HA (non-hassio) in Docker in Ubuntu. After reboot of machine, all containers (HA, Node-Red, Grafana and many others appear to be running (when looking in Portainer), but the HA gui does not appear - I cannot login. Here is some log:
https://pastebin.com/aaWgehMy
Appears to be some trouble with Unifi (search for “19:38:58” timestamp). And after that something with “Pendulum” at timestamp “19:39:24”.
I am not very technical - a bit lost here… Any hints?
I managed to fix the “Pendulum” thing by upgrading Python Pip to latest. But the unifi thing still persists, and I can still not get into HA UI
I can’t see the pastebin because I’m behind a corporate firewall that blocks it but there was a breaking change for unifi in 0.109. Read the release notes.
I have - and found this: https://github.com/home-assistant/core/pull/32817
but do not know what to do about it… is there a way I can disable to Unifi integration without the UI?
Here is the snippet from the log that appears to about unifi:
*2020-05-03 19:38:58 ERROR (MainThread) [aiounifi.api] Couldn't find key:*
*2020-05-03 19:38:58 WARNING (MainThread) [homeassistant.components.unifi.switch] Entity switch.unifi_poe_8e_56_9a_98_89_de reports faulty device  or port*
*2020-05-03 19:38:58 ERROR (MainThread) [homeassistant.components.switch] Error while setting up unifi platform for switch*
*Traceback (most recent call last):*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 186, in _async_setup_platform*
*    await asyncio.gather(*pending)*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 295, in async_add_entities*
*    await asyncio.gather(*tasks)*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 445, in _async_add_entity*
*    entity.async_write_ha_state()*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 297, in async_write_ha_state*
*    self._async_write_ha_state()  # type: ignore*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 320, in _async_write_ha_state*
*    state = self.state*
*  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 608, in state*
*    return STATE_ON if self.is_on else STATE_OFF*
*  File "/usr/src/homeassistant/homeassistant/components/unifi/switch.py", line 172, in is_on*
*    return self.port.poe_mode != "off"*
*AttributeError: 'NoneType' object has no attribute 'poe_mode'*
Was the unifi integration defined in yaml or the UI?
Do you have samba and/or ssh set up?
The integration was done in the UI. I do not have samba or ssh set up, but I can access the HA config directory OK via my linux (the configuration.yaml, customize.yaml etc) and subfolders
I can also bash into the container from Portainer (if that is relevant - sorry, not so savvy…)
Then you’re screwed.
Disabling a yaml config would have been simple.
The UI integration config is hidden in the undocumented .storage files.
Hence the major bun fight over here: The future of YAML
I’d try removing nordpool from your custom_components and see if that helps.
Heureka - with the nordpool stuff purged from custom_components - I can get into the UI!!
Now, I better kill the unifi integration from the UI and set it up in yaml instead?
You can’t. That’s what the whole topic I linked to is about.
I’d report the error on github.
