Hi all!
I’ve read a lot during last months here and on other websites trying to figure out what can be the root cause of this… but I’m unable to fix it! I’m really tired to try new actions without results, so finally I decided to ask here
Some time ago I’ve changed my ISP & router, which forced to change old subnet (192.168.0.1/24) to a new one (192.168.1.1/24).
I’m running HA in a Raspbery running HASSIO, and it’s wired connected to the network, being configured with a static ip address.
I’ve been able to change -using command line- the old ip to the new one, and the raspberry/hassio seems to be working a bit fine. Also some addons are
Thing working fine:
- From another PC in the same subnet I can ping homessistant.local , it resolves the correct IP (192.168.1.15).
- Connect thru shh from localhost to 192.168.1.15 (with “ssh hassio @192.168.1.15”)
- I can successfully other PC’s in the same subnet. Also ping the gateway, and also ping to www. google .com
- Uptime Kuma (monitoring addon) seems to be working fine as I’m receiving telegram messages from my HA account warning me about public IP’s when they fail/recover.
- I can work with the Raspberry using the Home Assistant command line, because I’ve connected it to a display using an HDMI cable.
- Ports scan done from the same subnet, detecting the following ports open:
IP: 192.168.1.15
Ping: 1 ms
Hostname: HOMEASSISTANT
Ports: 22,53,111,139,443,445,1880,1883,1884,3001,3306,3765,4357,8883,8884
Things NOT working:
- Unable to ssh from another computer in the same network (ssh hassio @192.168.1.15, gives the following error: “kex_exchange_identification: read: Connection reset by peer”). It neither works doing the same to homeassistant.local
- Unable to access Home Assistant URL (http://homeassistant.local:3765/ neither http://192.168.1.15:3765/) from the same subnet. I receive the following error: This site can’t be reached The connection was reset.".
- Unable to access Observer URL (http ://homeassistant.local:4357/ neither http ://192.168.1.15:4357/) from the same subnet. I receive the following error: This site can’t be reached The connection was reset.".
What’s missing to get this fixed??
It seems like the Raspberry itself works fine, and also some addons are working as expected -and connecting to internet!-, but seems that the Home Assistant or the Supervisor doesn’t get the network change well… probably is something missing to be updated in some config somewhere… ¿?
also some addonds
