Ha unreacheable after mesh router restart
(long time problem trying to be resolved)
i have two huawei ax3 connected via mesh/link+.
the raspberry running haos is connected to the satellite, then the satellite goes offline (i.e a restart). when the satellite is up again the raspberry will reconnect, the ha frontend is now unreacheable.
at this point i need to restart the main router too... haos network is configured on auto.
any idea?!
thanks
You mentioned that HAOS network settings is configured on auto? Don't recommend that. Either assign a static-IP in the network settings of HAOS that are outside the DHCP range or use DHCP reservation on your router to assign a static-IP. If I had to guess, this is why you're having issues trying to access HAOS frontend right now.
static ip solved the problem, thanks... omg "years" searching around for a solution
Hi Pietro, good that your problem is solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
