I am new to HA,
I followed the tutorial to install HA on RASPI 5/4GB RAM from SD card, but I can not get through the last log message : System Autofix complete. After showing that for few minutes, OS seems to shutdown (yellow LED truns to red, from previously IP visible in the LAN, no longer is present) replacing SD card did not help.
Any ideas?
…last few lines from end of LOG:
[supervisor.resolution.checks.base] Run check for security/core [supervisor.resolution.checks.base] Run check for no_current_backup/system [supervisor.resolution.module] Create new suggestion create_full_backup - system / None [supervisor.resolution.module] Create new issue no_current_backup - system / None [supervisor.resolution.checks.base] Run check for docker_config/system [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server [supervisor.host.services] Updating service information [supervisor.host.network] Updating local network information [supervisor.resolution.checks.base] Run check for free_space/system [supervisor.resolution.checks.base] Run check for multiple_data_disks/system [supervisor.resolution.check] System checks complete [supervisor.resolution.evaluate] Starting system evaluation with state running [supervisor.host.sound] Updating PulseAudio information [supervisor.host.manager] Host information reload completed [supervisor.resolution.evaluate] System evaluation complete [supervisor.resolution.fixup] Starting system autofix at state running [supervisor.resolution.fixup] System autofix complete
