Hello all,
I’m very happy with my switch from Homey to Home Assistant with endless possibilities in frontend, dashboarding and all other extra functions!
However, since a couple of weeks my Home Assistent is not stable, and stops working (partly) withing 24 hours.
My Hardware:
- Raspberry Pi 4B - 8GB RAM
- SSD Kingston SA400S3 (480 GB) - USB 3.0
- ConBee II Zigbee USB - USB 2.0
- Official Power supply from Raspberry Pi
- P1 Smart Meter USB connected for Utilities - USB 2.0
- Connected via UTP cable
Installed Add-ons:
Installed HACS - Integrations:
- Miele Integration
- Fully Kiosk Browser
- Afvalinfo
- Variables+History
- Eufy Security
Installed HACS - Frontend:
- Multiple Entity Row
- Lightalarm Card
- Button-card
- Time Picker Card
- Mini Media Player
- mini-graph-card
- simple Thermostat
- timer bar card
What I’ve tried so far:
- Changed to other power supply
- removed the P1 USB cable
- used backups from before the crashes
- downgraded the supervisor / core
- removed non essential HACS addons
- Moved from the standard recorder to MariaDB and limited what is recorded
- Moved the Pi (very happy with the storage:
What happens:
- The errors / stalling of the system happens randomly, in general when i’m NOT using the frontend (like during the night, or after a whole days of work on my Grafana Dashboard).
- When the crash happens, I see in the frontend that my Zigbee Devices are not working any more (unaivalable)
- other devies, such as Tuya or Shelly are still working (in the frontend as the real switching of the light).
- When I go to Supervisor, it doesn’t load
- When I go to Configuration and check config it says: Config not found
- When I press reboot / restart HA, I get an error (nothing happens)
- the only thing that helps and works is pulling the power and reconnecting after a while, everything boots up normally
The errors I’m able to retrieve in the “zombie state” as they come-in:
Logger: dsmr_parser.clients.protocol
Source: /usr/local/lib/python3.9/site-packages/dsmr_parser/clients/protocol.py:124
First occurred: 17:28:31 (1 occurrences)
Last logged: 17:28:31
disconnected due to exception
File "/usr/local/lib/python3.9/site-packages/serial_asyncio/__init__.py", line 114, in _read_ready
File "/usr/local/lib/python3.9/site-packages/serial/serialposix.py", line 595, in read
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Logger: homeassistant.components.recorder
Source: components/recorder/__init__.py:924
Integration: Recorder (documentation, issues)
First occurred: 17:28:34 (1 occurrences)
Last logged: 17:28:34
SQLAlchemyError error processing event <Event time_changed[L]: now=2021-12-07T17:27:41.002357+01:00>: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 697, in _process_one_event_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 835, in _process_one_event
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 898, in _commit_event_session_or_retry
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 924, in _commit_event_session
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 1428, in commit
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/orm/session.py", line 836, in commit
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2330, in commit
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2529, in _do_commit
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 532, in _invalid_transaction
sqlalchemy.exc.PendingRollbackError: Can't reconnect until invalid transaction is rolled back. (Background on this error at: https://sqlalche.me/e/14/8s2b)
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:557
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 17:29:03 (1 occurrences)
Last logged: 17:29:03
Can't read Supervisor data:
Logger: homeassistant.components.influxdb
Source: components/influxdb/__init__.py:575
Integration: InfluxDB (documentation, issues)
First occurred: 17:29:11 (1 occurrences)
Last logged: 17:29:11
Cannot connect to InfluxDB due to 'b'{"error":"engine: error writing WAL entry: write /data/influxdb/wal/homeassistant/autogen/25/_00006.wal: read-only file system"}\n''. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible.
Logger: homeassistant.components.hassio.handler
Source: components/hassio/handler.py:230
First occurred: 17:29:03 (8 occurrences)
Last logged: 17:30:33
/store return code 500
/supervisor/info return code 500
/addons return code 500
Source: components/hassio/websocket_api.py:109
First occurred: 17:29:06 (6 occurrences)
Failed to to call /supervisor/info -
Failed to to call /addons -
Failed to to call /store -
Logger: aiohttp.server
Source: config.py:936
First occurred: 17:30:52 (1 occurrences)
Last logged: 17:30:52
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 92, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 138, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
File "/usr/src/homeassistant/homeassistant/config.py", line 936, in async_check_ha_config_file
ImportError: cannot import name 'check_config' from 'homeassistant.helpers' (/usr/src/homeassistant/homeassistant/helpers/__init__.py)
