HA Update 2022.4.0 and errors
This morning I saw that the April update 2022.4.0 for HA was there so I ran the Check Home Assistant Configuration.
This what I normally do so as to avoid downgrading where possible.
These were the errors.
Edit I now have the full log below
INFO:homeassistant.util.package:Attempting install of colorlog==6.6.0
e[1mTesting configuration at /tmp/confige[0m
INFO:homeassistant.helpers.storage:Migrating core.entity_registry storage from 1.5 to 1.6
INFO:homeassistant.util.package:Attempting install of pycryptodome>=3.6.6
INFO:homeassistant.util.package:Attempting install of zeroconf==0.38.4
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of pyhik==0.3.0
INFO:homeassistant.util.package:Attempting install of rflink==0.0.62
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.4.32
INFO:homeassistant.util.package:Attempting install of fnvhash==0.1.0
INFO:homeassistant.util.package:Attempting install of lru-dict==1.1.7
INFO:homeassistant.util.package:Attempting install of ephem==4.1.2
INFO:homeassistant.util.package:Attempting install of paho-mqtt==1.6.1
INFO:homeassistant.util.package:Attempting install of python-forecastio==1.4.0
INFO:homeassistant.util.package:Attempting install of psutil==5.8.0
INFO:homeassistant.util.package:Attempting install of pvo==0.2.2
WARNING:homeassistant.components.integration.sensor:The 'unit' option is deprecated, please remove it from your configuration
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.54.0
INFO:homeassistant.util.package:Attempting install of scapy==2.4.5
INFO:homeassistant.util.package:Attempting install of aiodiscover==1.4.8
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20220405.0
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.5.0
INFO:homeassistant.util.package:Attempting install of async-upnp-client==0.27.0
INFO:homeassistant.util.package:Attempting install of pyudev==0.22.0
INFO:homeassistant.util.package:Attempting install of pillow==9.0.1
INFO:homeassistant.util.package:Attempting install of PyTurboJPEG==1.6.6
INFO:homeassistant.util.package:Attempting install of pysensibo==1.0.9
INFO:homeassistant.util.package:Attempting install of aiofiles==0.6.0
INFO:homeassistant.util.package:Attempting install of mutagen==1.45.1
INFO:homeassistant.util.package:Attempting install of gTTS==2.2.4
e[1;37mFailed confige[0m
  e[1;31mGeneral Errors:e[0m e[31me[31m
    - Platform error fan.smartir - cannot import name 'ATTR_SPEED' from 'homeassistant.components.fan' (/usr/local/lib/python3.9/site-packages/homeassistant/components/fan/__init__.py)
e[0m
e[1;37mSuccessful config (partial)e[0m
I did not update from 2022.3.8 to 2022.04.0 Ns staying with 2022.3.8 until I can run the checker error free.
There has been an issue raised with SmarIR on Githib Unable to setup smartir fan in next HA version (2022.4.b04) · Issue #817 · smartHomeHub/SmartIR · GitHub
I don’t understand the warning about
WARNING:homeassistant.components.integration.sensor:The ‘unit’ option is deprecated, please remove it from your configuration
Can anyone enlighten me please?
Anywhere you have unit in your template sensors needs to be removed.
Thanks for replying
I have a few entries like this
sensor 10:
  - platform: integration
    source: sensor.solarpower
    method: left
    unit: kWh
    unit_prefix: k
    unit_time: h
    round: 2
So I have to remove the “unit: kWh”?
What about “unit_prefix: k” and similar?
I also have “unit_of_measurement”
    sensors:
      exporting:
        friendly_name: "Current Energy Exporting"
        value_template: "{{ [0, (states('sensor.envoy_current_energy_production') | int - states('sensor.power_usage_3420') | int)] | max }}"
        unit_of_measurement: 'W'
      importing:
        friendly_name: "Current Energy Importing"
        value_template: "{{ [0, (states('sensor.power_usage_3420') | int - states('sensor.envoy_current_energy_production') | int)] | max }}"
      solarpower:
        friendly_name: "Solar Power"
        value_template: "{{ states('sensor.envoy_current_energy_production')}}"
I was reading that this term was depreciated so confused as to what I have to remove??
I assume that I would do this after I had updated to 2022.4.0?
Is there any before and after examples?
I don’t see those in the updated docs, so probably.
That is in the docs, so it should be okay.
Yes I commented out the “unit:” in 10 places in my configuration.yaml and now no warning errors.
Thank you.
