HA Update buggered up NodeRed and MQtt and not sure how to fix
so yesterdays HA Update buggered up things for me… i had to re install several addons
well after that now node red giving me issues
  1. [12:20:35] FATAL: [12:20:35] FATAL: SSL has been enabled using the ‘ssl’ option, [12:20:35] FATAL: this requires an SSL certificate file which is [12:20:35] FATAL: configured using the ‘certfile’ option in the [12:20:35] FATAL: add-on configuration. [12:20:35] FATAL: [12:20:35] FATAL: Unfortunately, the file specified in the [12:20:35] FATAL: ‘certfile’ option does not exist. [12:20:35] FATAL: [12:20:35] FATAL: Please ensure the certificate file exists and [12:20:35] FATAL: is placed in the ‘/ssl/’ directory. [12:20:35] FATAL: [12:20:35] FATAL: In case you don’t have SSL yet, consider getting [12:20:35] FATAL: an SSL certificate or setting the ‘ssl’ option [12:20:35] FATAL: to ‘false’ in case you are not planning on using [12:20:35] FATAL: SSL with this add-on. [12:20:35] FATAL: [12:20:35] FATAL: Check the add-on manual for more information.
and if i set SSL to false and i get the node red to start… i get this error then Credentials could not be decrypted The flow credential file is encrypted, but the project’s encryption key is missing or invalid. The flow credential file will be reset on the next deployment. Any existing flow credentials will be cleared.
and MQTT not 100% working in node red mqtt it shows connecting it wont connect to the 1883 server on the HA server… so i not sure what has gone wrong
but i having issues… so i could use some help to get things back up and running… as my home automations dont work now with MQTT down inside node red
and mqtt server will start then it stops here is the log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[14:05:56] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[14:05:56] INFO: Starting NGINX for authentication handling...
s6-rc: info: service legacy-services successfully started
[14:05:57] INFO: Starting mosquitto MQTT broker...
1702062357: Error: Unable to open include_dir '/share/mosquitto'.
1702062357: Error found at /etc/mosquitto/mosquitto.conf:37.
[19:05:57] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
[19:05:57] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
oh and the mqtt log shows errors as it wont work either with node red to connect with any of the things
[16:37:45] INFO: SSL is not enabled
[16:37:45] INFO: Starting NGINX for authentication handling...
[16:37:46] INFO: Starting mosquitto MQTT broker...
2023-12-08 16:37:46: Warning: Mosquitto should not be run as root/administrator.
2023-12-08 16:37:46: mosquitto version 2.0.18 starting
2023-12-08 16:37:46: Config loaded from /etc/mosquitto/mosquitto.conf.
2023-12-08 16:37:46: Loading plugin: /usr/share/mosquitto/go-auth.so
2023-12-08 16:37:46:  ├── Username/password checking enabled.
2023-12-08 16:37:46:  ├── TLS-PSK checking enabled.
2023-12-08 16:37:46:  └── Extended authentication not enabled.
2023-12-08 16:37:46: Opening ipv4 listen socket on port 1883.
2023-12-08 16:37:46: Opening ipv6 listen socket on port 1883.
2023-12-08 16:37:46: Opening websockets listen socket on port 1884.
2023-12-08 16:37:46: mosquitto version 2.0.18 running
2023-12-08 16:37:46: New connection from 127.0.0.1:57318 on port 1883.
2023-12-08 16:37:46: Client <unknown> disconnected due to protocol error.
[16:37:47] INFO: Successfully send discovery information to Home Assistant.
[16:37:47] INFO: Successfully send service information to the Supervisor.
2023-12-08 16:38:30: New connection from 192.168.0.12:50405 on port 1883.
2023-12-08 16:38:30: New client connected from 192.168.0.12:50405 as 5GQjdTjb1wJHfhPVDWrrfo (p2, c1, k60, u'mqtt-user').
2023-12-08 16:38:51: New connection from 192.168.0.12:47816 on port 1883.
error: received null username or password for unpwd check
2023-12-08 16:38:51: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:39:06: New connection from 192.168.0.12:40360 on port 1883.
2023-12-08 16:39:06: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:39:21: New connection from 192.168.0.12:43536 on port 1883.
2023-12-08 16:39:21: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:39:36: New connection from 192.168.0.12:56004 on port 1883.
2023-12-08 16:39:36: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:39:51: New connection from 192.168.0.12:36934 on port 1883.
2023-12-08 16:39:51: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:40:06: New connection from 192.168.0.12:35612 on port 1883.
2023-12-08 16:40:06: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:40:21: New connection from 192.168.0.12:41084 on port 1883.
2023-12-08 16:40:21: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:40:36: New connection from 192.168.0.12:44112 on port 1883.
2023-12-08 16:40:36: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:40:51: New connection from 192.168.0.12:58048 on port 1883.
2023-12-08 16:40:51: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:41:06: New connection from 192.168.0.12:52374 on port 1883.
2023-12-08 16:41:06: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:41:18: New connection from 172.30.32.2:33910 on port 1883.
2023-12-08 16:41:18: Client <unknown> closed its connection.
2023-12-08 16:41:21: New connection from 192.168.0.12:50028 on port 1883.
2023-12-08 16:41:21: Client nodered_91f7db5099b95087 disconnected, not authorised.
2023-12-08 16:41:36: New connection from 192.168.0.12:41952 on port 1883.
2023-12-08 16:41:36: Client nodered_91f7db5099b95087 disconnected, not authorised.
