Hi guys,
I recently wiped my pi and reinstalled HA after several failed attempts I went for the AIO installed,. is there a quick way via command to check your config settings and reboot HA?
previously I checked the configs via
hass --script check_config -c /path/to/config
and I used the below to restart
sudo service hass-daemon restart
how is the done if used the AIO to install HA?
cheers guys
