HA Virtual Box VDI does not capture Z-Wave USB dongle on startup
On the same host, I run several VMs, each is configured to capture their own devices on startup and they all work except for the HA VDI.
With the HA VDI, it does not capture the Z-Wave USB stick on startup. I have to manually click on the VM’s config device>USB once the VM starts to capture the stick so HA can see all the Z-Wave devices. There are no other VMs contenting for the same USB stick (I’ve disabled others, same problem).
I know some might say this is a VB problem, and it might be, but the HA VM is the only one I am having a problem with, so if anyone has an insight, I’d really appreciate it.
