Failed config
media_source.http_request: [source /data/packages/dc43710d/home-assistant-voice.yaml:1558]
Component media_source.http_request requires component http_request.
platform: http_request
buffer_size: 500000
Failed config
buffer_size: 500000
I get the same error when trying to update since updating to HA 2025.12
I think I accidentally “took control” of my HA voice PE device, and until this release I could update the device through my ESP Home Builder.
The yaml code used in ESP Home is this:
substitutions:
friendly_name: Ha voice LR
packages:
Nabu Casa.Home Assistant Voice PE: github://esphome/home-assistant-voice-pe/home-assistant-voice.yaml
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: AqWIOxVehj3oCGZdkP8S1EjUAZJ1gxBUom7TjtAgqE8=
wifi:
ssid: !secret wifi_ssid
to update with device builder you must take control.
i use the default image
what error do you receive
It stopped working after the last update of esphome builder.I use the firmware from Nabu casa and I have never changed anything in the yaml
Failed config
buffer_size: 500000
This is the output I get when I try to run the update:
INFO ESPHome 2025.12.0
INFO Reading configuration /config/esphome/home-assistant-voice-0911d3.yaml...
INFO Updating https://github.com/esphome/home-assistant-voice-pe@dev
INFO Updating https://github.com/esphome/esphome@72499eaed2ed54316aca90d368053aa2e1a54f5f
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq/#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
Failed config
buffer_size: 500000
The error explains that you need to add “http_request” component
Not sure why it is required now. These did not require before.
You may get more errors but that should take care of that one
If you take control and only want to overwrite a few keys, you might have this in your config:
packages:
Which imports the default config (this file):
And in the latest release this was added beside a lot other lines:
sendspin:
task_stack_in_psram: true
kalman_process_error: 0.01
media_source:
- platform: sendspin
- platform: http_request
buffer_size: 500000
What seems to be missing is the include of the referenced http_request platform like shown in the post from @tmjpugh.
To me, this looks like a bug in this default config.
Ah well, should have looked at the issues:
Wasn’t aware of home-assistant-voice.factory.yaml.
But given the fact that “taking control” seemed to add this line automatically, this problem will pop up for many people I guess.
It works now.Thanks for help
Yes, I can confirm that this solved the problem.
Thanks a lot !
