Hi, just wondering what’s the best way to run HA, and a web server together on a Pi?
Currently, I’m using HASSOS with Portainer, but not too sure if that’s really ideal and use a Docker instead?
Would appreciate help, thanks!
Just run an additional container with the web server. Home Assistant is using 8123 by default, thus you can use 80 for your web server.
Would it better to install HA using docker instead of HassOS?
