HA will not restart or load
I’m new to HA and have a HA green I’ve recently just got everything up and running and was happy with my progress. I’ve experienced a power cut today and HA is in recovery mode, I’ve reset the green, and tried to restart the HA browser but got the below message.
You have made an edit in one of your config files that HA doesn’t like and it’s preventing restart so you don’t get into a bad situation. (read: be glad recovery mode exists or you’d be completely unable to talk to HA right now)
Its telling you what the problem is in those errors so you need to open those files and fix the issue.
Its probably the last changes you made before the power cut.
Also changes to your configuration.yaml won’t take effect until reboot so next time you edit those be sure to restart so you’re not suprised after a power cut.
Yes, I’ve found it it was a half-installed Spotify player I was working on a couple of days ago.
Thanks again.
