HA with 22 monitor?
Actually i installed HA (supervized) on my raspberry. (Debian Bullseye)
I would like to display my dashboard on 22 monitor in my living room.
What are choices ?
Thank you
Fabien
Anything that can display a web page.
I’m using this: Raspberry Pi Kiosk using Chromium - Pi My Life Up on a separate Rpi3 behind the monitor.
When you say “separate”, it means that you have one Rpi for HA and one for display ?
Isn’t it possible to have all in one ?
Sorry if i don’t understand, i begin with HA…
Depends on, how you setup your HA server.
If you use HAOS on a RPI, the it won’t work, because HAOS is a headless system without monitor output.
You could use HA supervised installation, then it will be possible, but supervised install is not recommended for beginners.
I have a mini PC running HA, but the screen with the RPi kiosk is in completely different room. That is, what makes this approach more flexible.
Ok, thank you for your answer!
I’ll buy a mini pc to install HAOS.
What did you install as OS on your mini pc ? Debian ? or did you let preinstalled Windows 11 ?
So i’ll keep my Rpi for displaying on my touch monitor.
For this last step (display on monitor with my raspberry), what is the easy / best method ?
Lauch browser (Chomium) in full screen ?
Debian Bullseye on the server.
Raspbian on the Pi.
