I really like the idea of being able to access HA on my Android Auto screen. But I do not want to have to dig through a bunch of menus (choose whether I want a switch, light, cover etc) just to get to what I need.
There are very few items that I’d want to see on the screen under HA. I’d like to be able to create a dashboard that shows the few items I want to access and assign THAT dashboard to be used in Android Auto.
unfortunately not in teh android auto interface, no webviews are allowed there so the app needs to build a custom screen. Current implementation is to let users control all entities
i actually submitted a PR for this a couple days ago, needs to go through review process then you will be able to select favorite entities to appear in a new category in the android auto app.
you need to access the app settings to do that, unfortunately if you installed via the google play store the settings button is hidden there per Googles requirement.
i was able to force my way by enabling notification from the app then in HA push a notificaiton to it and when you open the notification a full HA app open ! but I don’t know if you can make it default
no and that only works when parked, Google specifically blocks it and has that logic in place to switch to the driving optimized screens when not in park.
with that said hopefully they never hear about that workaround
Could I “hack” into my car system from there ? there is a lot of limitaiton in my car system so I tought that maybe i could use home assistant to open let said the default android file explorer ( that i know it’s install but can’t find a way to lunch it )
I tried things like adding a button in home assistant and call the file explorer :
