Hi all
I have an issue with HA in conjunction with Kemp load balancer running as reverse proxy.
HA works just fine on the local network accessing it via the local ip and port 8123. All good there. However if the request/traffic comes from the proxy, it just displays the cloudflare host error (520) and logs an error in HA.
I have configured HA like this: (version 2021.11.5)
http:
server_port: 8123
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.15 #Virtual IP from the proxy
Each time i try to access it via the proxy/subdomain i get following error in HA logs:
Logger: aiohttp.server
Source: /usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py:393
First occurred: 16.34.22 (4 occurrences)
Last logged: 16.45.40
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 314, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'invalid HTTP method'"
Kemp is setup with certificate from cloudflare and everything else works as intended. Multiple other services, have not posed any issues like HA, while setting up reverse proxy.
Do i need to enable HTTPS (or disable it?) on HA? if so, how? None of the other proxied services have any certs installed and works flawlessly with no raised cert flags in chrome.
Troels
