Hi All,
I need to some help setting up the RFXCOM module in combination with the Harrison Curtains.
My configuration.yaml for the rfxcom module looks like:
rfxtrx:
device: /dev/ttyUSB0
debug: True
But how do i get the Harrison Curtains configured? Via the rfxmngr application i know the house codes and Unit codes. Opening an Closing via the rfxmngr is no problem.
When adding the rfxtrx config into the configuration.yaml, should i see something in the UI for this device? I see for example the Zwave USB stick.
Thanks!
