HA with Tasmota flashed Sonoff s20 - no local switch
i got 2 Sonoff s20, flashed with tasmota firmware an added as “light” to the HASSio.
I can swicth them over the web in hass.io.
What i cant do is switch the state directly at the power-outlet with the button.
It switches instantly back to the “web.state”.
Whats wrong and how can i fixe this?
I already tryed the “retain” option with no change.
Take a look at the Switch Modes of Tasmota.
thanks, that should do what i want, but i cant see HOW i get these commands to my sonoff s20
in konsole SwitchMode 2 or siwtchmode=2 “command not known”
Note sure about the numbers, but according to the docs, it should be SwitchMode1 2.
I used SwitchMode2 3 for a external button on a sonoff basic.
thanks, but i see it that it should work in console, command seeams ok,
but when i press my local button, is isntalty switched back :-/
do you have maybe retain: true set in your config? Maybe this has something to do with it?
i tryed with retain true and retain false
with retain false, i cant switch it on the website. however ^^
did you set the Module_Type to 08 S20 Socket in the sonoff webinterface?
yes, is there any other config i oversee?
