HA with Victron with modbus
i was able to integrate Victron (RPI) with modbus in HA
i got the data in HA :slight_smile:
now in am trying to show text instead of value for the Solar Panel
‘0’ : ‘Off’, ‘2’ : ‘Fault’, ‘3’ : ‘Bulk’, ‘4’ : ‘Absorption’,‘5’ : ‘Float’
My formula work in developer Tool but not sure where to put this in the Configuration
  1. V-775-MQTT Charge State:
  2. 0=Off;2=Fault;3=Bulk;4=Absorption;5=Float;6=Storage;7=Equalize;11=Other (Hub-1);252=External control
  • value_template: >-
  1. {% set mapper = {‘0’ : ‘Off’, ‘2’ : ‘Fault’, ‘3’ : ‘Bulk’, ‘4’ : ‘Absorption’,‘5’ : ‘Float’ } %}
  2. {% set state = states.sensor.v_775_mqtt_charge_state.state %}
  3. {{ mapper[state] if state in mapper else ‘Unknown’ }}
My config
modbus: !include modbus.yaml
/config/modbus.yaml
modbus:
  • name: victron
type: tcp
host: 192.168.X.XX
port: 502
sensors:
  • name: “V-775-MQTT Charge State”
slave: 239
address: 775
Any help would be appreciate!
image|655x373
template:
  - sensor:
      - name: "Charge State"
        state: >
i add this to the configuration yaml… but the sensor/entity does not show up
it working…
Tks a lot :slight_smile:
