I have ZME_UZB1 installed and working on my HA. I also have a SmartThings (ST) hub running Z-Wave. Can I add the two together? I thought I should be able to? I can see it (and even add it) but I don’t see the other Z-Wave devices
The ST runs in secure mode and I can not find the network key so does that stop me joining?
At a high level I want my HA to “see” all of the Z-Wave devices in my house. At the moment they are all “on” the ST Z-Wave, so can I add my HA to the Z-Wave and then see everything?
To try and answer your question in my ignorant way, I would guess I want to add my HA to the existing Z-Wave network? I don’t want a second network?
Either you move all your devices from SmartThings to the ZME_UZB1 stick and remove SmartThings or you remove the ZME_UZB1 stick and integrate SmartThings into Home Assistant.
You don’t add HA to your network, it will only read/write to the network but it will not be an entity in the network.
If I take a look at what is on my ST (as Z-Wave) there is not much so I could remove one at a time from ST and then add to HA? That would be a careful way to try?
eg; move a button/plug or similar?
