Hello i have a lot of problems but first this one to start.
first mine appology English is not mine main language so i hope it is nearly good understandeble.
I have spent many ours to figure this out but i cant solve the problem.
I have make this in confi.yaml
But when i remove the two # by include automations and by customize mine HA doesnt start up.
What have i do wrong in in mine automation file are several automations that works fine and in mine customize file i onley have this
The system cannot restart because the configuration is not valid: Error loading /config/configuration.yaml: expected โโ, but found โโ in โ/config/customize.yamlโ, line 22, column 1
So that is fast i have tried and it works thankyou very much but now i,am currius why is by
homeassistant:
customize: !include customize.yaml
a free space at the beginning
Mine automation yaml is ok but mine customize.yaml
I,am bisy with a picture element card that looks great already but i wanted a shorter name for mine entity
I have this
Thank you for you help
I muss admit i have done that already but i have 10 sensors named 01-10
But when i changed that itsto hard to remember wich is one
But as this the only working solutioni have no choiche.
Thx again
