ok guys, this is kind of annoying…hope somebody can help !
I had a perfectly fine running hassos on a rp4 (32bit mode). A zwave usb device from sigma and everything was fine.
then came the host update from 3.13 to 4.8 which, from what I can see, ruined many installations - or at least they didnt boot anymore.
So I SSHed into my installation, which was still possible and went back to 3.13 via CLI. But it still doesnt boot. That is, it does boot. I can get into the folders via SAMBA plugin. At times I could still SSH in (that plugin was somehow disabled tho, had that in the past, can still get into the CLI via a connected monitor).
With samba access I do have logs but there is nothing obvious, nothing I didn’t have before.
If I do “ha core stats” I notice that rx / tx packages are at Zero which fits to me not being able to get into the WebGUI.
What did I try ?
- as I said, go back to 3.13.
- restore various snapshots (have one every day for the last 10 days)
- did a NEW install with 4.9, restored snapshots, same result
My problem is that the logs give me nothing. I dont see the problem and the initial issue from the host update should be fixed by my rollback attempt AND is also fixed in 4.9.
As I’m writing this I remember, that I didnt reboot the host system in quite a while, most certainly the last time was before the time range from my snapshots.
My installation is rather complex so completely restarting from scratch would be a major pain in the butt…any help is very much appreciated !!
2020-06-05 22:09:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for logbook_cache which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-05 22:09:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-05 22:09:58 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-05 22:10:03 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=87 from 2020-06-05 19:32:35)
2020-06-05 22:10:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for climate_group which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-05 22:10:10 WARNING (MainThread) [homeassistant.components.climate] ClimateDevice is deprecated, modify ClimateGroup to extend ClimateEntity
2020-06-05 22:10:12 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for samsungtv_tizen which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-06-05 22:10:17 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2020-06-05 22:10:18 ERROR (MainThread) [homeassistant.components.hue] Error connecting to the Hue bridge at 192.168.178.37
2020-06-05 22:10:18 WARNING (MainThread) [homeassistant.config_entries] Config entry for hue not ready yet. Retrying in 5 seconds.
2020-06-05 22:10:19 ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed client session
2020-06-05 22:10:21 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Zuhause for smartthings
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 217, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/smartthings/__init__.py", line 120, in async_setup_entry
entry.data[CONF_REFRESH_TOKEN],
File "/usr/local/lib/python3.7/site-packages/pysmartthings/smartthings.py", line 210, in generate_tokens
client_id, client_secret, refresh_token
File "/usr/local/lib/python3.7/site-packages/pysmartthings/api.py", line 424, in generate_tokens
raise APIInvalidGrant(data.get("error_description"))
pysmartthings.errors.APIInvalidGrant: Invalid refresh token: a5cac644-f2c6-4bb5-afa4-1b63f5d884e2
