HA Yellow CM4 lite install failed
Hey everyone, hoping someone could help with this issue.
Helping a friend install a new home assistant yellow with the cm4 light module. Cannot get it to write function correctly. We were at first only getting it green and red light. No yellow every light. I wiped the nvme and rated the USB key and it eventually installed one time. We were able to log in. Make some changes and play around with it but when we rebooted it would not boot back into. Ha. And stayed on a green and red light. Have tried multiple things such as :
New nvme
New usb key
Reseating cm4
Tired the holding down the blue and red button and then starting again with a fresh flashed USB key
Tried option 2 with rpiboot, but couldn’t seem to get this to work. Could get the com port to show up and putty to the com port but never was able to get the storage as an option and have it show up in the pieimage manager.
I set mine up with no problems but I have a model with onboard storage. Really unsure how it could be this problematic to get this installed. Must be missing something. Any ideas that would be appreciated.
