Dear all, i stuck with the migration of a HA blue to HA yellow.
I had a HA blue (Odroid N2+) installed in my motorhome (which is now in winterstorage, far away)
On the blue i used a ConBee II with the Deconz integration.
On the HA yellow i have checked the box to have Thread enable too… was a bit trigger happy.
The Thread integrations have been added, while the ZHA is not automatically added.
Is my manual setup correct?
integration: Zigbee Home Automation
device: /dev/ttyAMA1
radio type: EZSP = Silicon Labs EmberZNet protocol
Also note the note in cursive/fine-print text that informs/warns that only a partial migration is possible:
"Note: this procedure only helps migrate basic network settings to your Home Assistant SkyConnect, customizations like device names will be lost and automations will need to be updated. Most powered devices like lightbulbs will be re-discovered over time (you can speed this up by rebooting the device) but your battery-powered devices may need to be re-joined to the network for the migration to complete. There is currently no migration path to migrate all settings and devices."
That guide is written for Home Assistant SkyConnect but other than the device path those instructions should be very similar for the Home Assistant Yellow integrated radio module.
I think that you got the device path correctly with /dev/ttyAMA1 for UART/GPIO access if you have EmberZNet NCP firmware for Zigbee, but if you have RCP Multi-PAN firmware for multiprotocol support then believe you instead need to use the Home Assistant Add-on: SiliconLabs Zigbee/OpenThread Multiprotocol Add-on and set the device path to socket://core-silabs-multiprotocol:9999
Though if you have enabled RCP Multi-PAN firmware with multiprotocol support then you must instead use socket address with TCP port after have installed Home Assistant Add-on: SiliconLabs Zigbee/OpenThread Multiprotocol Add-on.
Ok.
i followed this guide here: Flash Silicon Labs radio firmware manually · NabuCasa/silabs-firmware Wiki (github.com)
using this firmware: NabuCasa_Yellow_EZSP_v6.10.3.0_PA32_ncp-uart-hw_115200.gbl
Did it several times without sucess. Guess a clean restart after deactivating the addons and integrations is important.
to paste the code, I used shift+insert, then it worked.
@Hedda thanks for your hint with the manual Home Assistant SkyConnect (home-assistant.io)
It did work with one test device, as i dont have my motorhome available at the moment and the device need to be online, i will have to do that later.
For reference noticed that the Home Assistant Yellow website and webpages do not contain the same information, nor do they in general look to contain as much information as the website and webpages for the Home Assistant Skyconnect USB dongle, even though they should tecnically work very similarly:
