HA Yellow - Error on Home Assistant installation
Hi all,
I’ve got a fresh new HA Yellow, that does not install.
After going to the troubleshooting (Symptom: Installation on Yellow kit: yellow LED keeps blinking – Home Assistant Yellow) I got further but stuck on the following, thats shown me on the HA Webpage:
2024-05-27 22:22:35.191 WARNING (MainThread) [supervisor.jobs] ‘Updater.fetch_data’ blocked from execution, no supervisor internet connection
2024-05-27 22:22:35.191 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
I can confirm that it has internet connection, I even installed a Hyper-V VM with HA , that is working.
It’s also not related to DNS or IPv6 issues.
The problem seems to be, that the date/time on the HA Yellow is around five month behind and therefore the ssl not working and the HA then says “No internet”.
But I have no idea how to change the time on the HA, on the webpage (http://homeassistant.local:8123/) , there is only the log file in live view with no possibility to interact, on the app it’s the same.
How can I simply just change the time???
Okay, didn’t manage to set the time.
But after installing the normal image of HA (from the raspberry imager) instead of the Yellow Image it started completly up, and changed to right date.
After that I could put the HA yellow image to the device and it worked.
