HA Yellow - flashing OpenThread only firmware
I already have a USB dongle with Zigbee and I want to use the embedded Zigbee/Thread chip only for Thread. I’m using the Silicon Labs Flasher add-on with this parameters:
The firmware was uploaded from: https://github.com/NabuCasa/silabs-firmware/tree/main/OpenThreadRCP with this specific URL fimware: https://github.com/NabuCasa/silabs-firmware/raw/main/OpenThreadRCP/NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl.
I’m getting this errors:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
 Add-on: Silicon Labs Flasher
 Silicon Labs firmware flasher add-on
 Add-on version: 0.2.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.5  (aarch64 / yellow)
 Home Assistant Core: 2023.9.1
 Home Assistant Supervisor: 2023.08.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[10:57:27] INFO: Detected Home Assistant Yellows6-rc: info: service s6rc-oneshot-runner: starting
[10:59:01] INFO: Starting universal-silabs-flasher with /dev/ttyAMA1 (bootloader baudrate 460800)
2023-09-11 10:59:02 core-silabs-flasher universal_silabs_flasher.flash[151] INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.3.1', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.3.1.0_GitHub-e6df00dd6' (2.3.1.0), fw_type=<FirmwareImageType.OT_RCP: 'ot-rcp'>, baudrate=460800)
2023-09-11 10:59:02 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Triggering Yellow bootloader
2023-09-11 10:59:03 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.GECKO_BOOTLOADER at 460800 baud
2023-09-11 10:59:05 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.SPINEL at 460800 baud
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\xfe'): ValueError('Invalid flag')
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x80'): ValueError('Invalid flag')
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x18'): ValueError('Invalid flag')
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x00'): ValueError('Invalid flag')
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x9e'): ValueError('Invalid flag')
2023-09-11 10:55:37 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\xe0'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x18'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x9e'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\xfe'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x00'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\xe0'): ValueError('Invalid flag')
2023-09-11 10:55:38 core-silabs-flasher universal_silabs_flasher.cpc[151] WARNING Failed to parse buffer bytearray(b'\x80'): ValueError('Invalid flag')
2023-09-11 10:55:39 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.EZSP at 115200 baud
Error: Failed to probe running application type
[10:55:44] INFO: universal-silabs-flasher-up script exited with code 1
s6-rc: warning: unable to start service universal-silabs-flasher: command exited 1
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
My HA info:
Home Assistant 2023.9.1 Supervisor 2023.08.3 Operating System 10.5 Frontend 20230908.0 - latest
What I’m doing wrong with the flash process? Any Ideas?
Thanks.
Finally, I successfully flashed my HA Yellow using the manual procedure described at Flash Silicon Labs radio firmware manually · NabuCasa/silabs-firmware Wiki · GitHub, using the Update Advanced SSH & Web Terminal add-on with “protection mode” disabled:
Before that, I have to install the packages described in the thread :Dependency failure when trying to install · Issue #15 · NabuCasa/silabs-firmware · GitHub, because the error: “ERROR: Could not build wheels for cffi, which is required to install pyproject.toml-based projects”:
apk add python3 python3-dev gcc libffi-dev libc-dev
This is the final output:
➜  OpenThreadRCP git:(main) universal-silabs-flasher --device /dev/ttyAMA1 flash                                               --allow-cross-flashing --firmware NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_                                              ot-rcp_hw_460800.gbl
2023-09-13 14:14:30 a0d7b954-ssh universal_silabs_flasher.flash[1006] INFO Extra                                              cted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.3.1', ezs                                              p_version=None, ot_rcp_version='SL-OPENTHREAD/2.3.1.0_GitHub-e6df00dd6' (2.3.1.0                                              ), fw_type=<FirmwareImageType.OT_RCP: 'ot-rcp'>, baudrate=460800)
2023-09-13 14:14:30 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Pro                                              bing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2023-09-13 14:14:30 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Lau                                              nched application from bootloader
2023-09-13 14:14:30 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Det                                              ected bootloader version '2.0.1'
2023-09-13 14:14:30 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Pro                                              bing ApplicationType.SPINEL at 460800 baud
2023-09-13 14:14:34 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Pro                                              bing ApplicationType.CPC at 460800 baud
2023-09-13 14:14:34 a0d7b954-ssh universal_silabs_flasher.cpc[1006] WARNING Fail                                              ed to parse buffer bytearray(b'\xf8'): ValueError('Invalid flag')
2023-09-13 14:14:38 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Probing ApplicationType.CPC at 115               200 baud
2023-09-13 14:14:43 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Probing ApplicationType.CPC at 230               400 baud
2023-09-13 14:14:47 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Probing ApplicationType.EZSP at 11               5200 baud
2023-09-13 14:14:48 a0d7b954-ssh universal_silabs_flasher.flasher[1006] INFO Detected ApplicationType.EZSP, ver               sion '7.3.1.0 build 176' (7.3.1.0.176) at 115200 baudrate (bootloader baudrate 115200)
2023-09-13 14:14:48 a0d7b954-ssh universal_silabs_flasher.flash[1006] INFO Cross-flashing from FirmwareImageTyp               e.NCP_UART_HW to FirmwareImageType.OT_RCP
NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##----------------------------------]    6%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##----------------------------------]    7%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##----------------------------------]    8%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###---------------------------------]    8%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###---------------------------------]    9%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###---------------------------------]    9%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###---------------------------------]   10%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###---------------------------------]   11%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####--------------------------------]   11%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####--------------------------------]   12%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####--------------------------------]   13%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####-------------------------------]   13%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####-------------------------------]   14%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####-------------------------------]   15%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####-------------------------------]   16%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######------------------------------]   16%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######------------------------------]   17%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######------------------------------]   18%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######------------------------------]   19%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######-----------------------------]   19%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######-----------------------------]   20%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######-----------------------------]   21%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######-----------------------------]   22%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########----------------------------]   22%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########----------------------------]   22%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########----------------------------]   23%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########----------------------------]   24%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########---------------------------]   25%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########---------------------------]   26%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########---------------------------]   27%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########--------------------------]   27%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########--------------------------]   28%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########--------------------------]   28%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########--------------------------]   29%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########--------------------------]   30%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########-------------------------]   30%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########-------------------------]   31%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########-------------------------]   32%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########-------------------------]   33%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############------------------------]   33%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############------------------------]   34%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############------------------------]   35%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############------------------------]   35%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############------------------------]   36%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############-----------------------]   36%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############-----------------------]   37%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############-----------------------]   38%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############----------------------]   38%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############----------------------]   39%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############----------------------]   40%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############----------------------]   41%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############---------------------]   41%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############---------------------]   41%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############---------------------]   42%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############---------------------]   43%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############---------------------]   44%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################--------------------]   44%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################--------------------]   45%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################--------------------]   46%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################--------------------]   47%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################-------------------]   47%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################-------------------]   48%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################-------------------]   48%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################-------------------]   49%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################------------------]   50%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################------------------]   51%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################------------------]   52%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################-----------------]   52%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################-----------------]   53%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################-----------------]   54%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################-----------------]   54%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################-----------------]   55%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####################----------------]   55%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####################----------------]   56%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####################----------------]   57%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####################----------------]   58%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####################---------------]   58%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####################---------------]   59%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####################---------------]   60%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#####################---------------]   61%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######################--------------]   61%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######################--------------]   61%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######################--------------]   62%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [######################--------------]   63%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######################-------------]   63%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######################-------------]   64%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######################-------------]   65%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#######################-------------]   66%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########################------------]   66%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########################------------]   67%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########################------------]   67%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########################------------]   68%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [########################------------]   69%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########################-----------]   69%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########################-----------]   70%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########################-----------]   71%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#########################-----------]   72%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########################----------]   72%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########################----------]   73%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########################----------]   74%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##########################----------]   74%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########################---------]   75%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########################---------]   76%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###########################---------]   77%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############################--------]   77%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############################--------]   78%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############################--------]   79%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [############################--------]   80%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############################-------]   80%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############################-------]   80%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############################-------]   81%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############################-------]   82%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#############################-------]   83%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############################------]   83%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############################------]   84%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############################------]   85%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##############################------]   86%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############################-----]   86%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############################-----]   87%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############################-----]   87%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###############################-----]   88%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################################----]   88%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################################----]   89%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################################----]   90%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [################################----]   91%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################################---]   91%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################################---]   92%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################################---]   93%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################################---]   93%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [#################################---]   94%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################################--]   94%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################################--]   95%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################################--]   96%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [##################################--]   97%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################################-]   97%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################################-]   98%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [###################################-]   99%               NabuCasa_Yellow_OpenThread_RCP_v2.3.1.0_PA32_ot-rcp_hw_460800.gbl  [####################################]  100%
I don’t know if the problem was because the Silicon Labs Flasher add-on can’t disable the “Protection Mode”
