I have a powered USB 2.0 hub plugged into my HA Yellow PoE with my Z-Wave dongle and a Bluetooth adapter with antenna. The Yellow will not boot with the hub plugged in, but as soon as I unplug it, the Yellow boots right up without issue and I can plug the hub in again immediately. Anyone know what’s up with that? It’s a problem because it means that Home Assistant doesn’t come back online automatically after a power outage.
Are you referring to external power?
If so, better check another powersupply or power plug, as it sounds like an issue with too much power drawn from the usb port on yellow🤔
