I have 8G CM4 and on the hardware section on HA it only shows 2
why is that>?
why is that>?
looks like Im having a problem and this can be explained by restoring from full backup from another instance that was 2GB need an expert help
## System Information
version | core-2024.3.0
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.12.2
os_name | Linux
os_version | 6.1.73-haos-raspi
arch | aarch64
timezone |
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4733
Installed Version | 1.34.0
Stage | running
Available Repositories | 1471
Downloaded Repositories | 45
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 12.0
update_channel | stable
supervisor_version | supervisor-2024.02.1
agent_version | 1.6.0
docker_version | 24.0.7
disk_total | 1833.7 GB
disk_used | 18.8 GB
healthy | true
supported | true
board | yellow
supervisor_api | ok
version_api | ok
installed_addons | Silicon Labs Multiprotocol (2.4.4), Terminal & SSH (9.10.0), AdGuard Home (5.0.4), Plex Media Server (3.5.0), Spotify Connect (0.13.0), Cloudflared (5.1.5), File editor (5.8.0), Z-Wave JS UI (3.4.0), Matter Server (5.4.1), OpenThread Border Router (2.5.0), ESPHome (2024.2.2), Tautulli (4.0.1), Silicon Labs Flasher (0.2.0), Whatsapp (1.3.5), Duck DNS (1.15.0), HAMC Server Bedrock (1.0.3), Nginx Proxy Manager (1.0.1), Filebrowser (2.23.0_12), Log Viewer (0.17.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 21
views | 6
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | March 1, 2024 at 10:23 AM
current_recorder_run | March 12, 2024 at 12:02 AM
estimated_db_size | 548.77 MiB
database_engine | sqlite
database_version | 3.44.2
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>```
maybe it is my fault at the end …sorry wrong cm4
