I have received my HA yellow 3 months ago. HA was up & running and I was gradually starting my migration from an old Rpi3. I basically had nothing done except install HA, mosquitto, ESPhome, etc.
This morning I noticed all LEDs were off on the yellow. No ping, no access to HA.
What I did:
- Check the PSU: it reads 12V+ on a voltage tester.
- Disassemble the CM4 module, plug it in: no LEDs
- Reassemble the CM4 module several times: no LEDs
All this with and without RJ45 plugged in or not.
I am about to cut the PSU wire so that I can reuse the jack connector and attempt using a DC voltage source I own, as a last chance scenario.
Am I missing anything until now? Your support would be greatly appreciated. Thanks a lot for your feedback!
