Received a new HA Yellow this week. The browser screen Preparing Home Assistant hangs for hours. Many errors in the log. Here is part of the log. I’m totally new to HA so I don’t know what could be wrong.
23-10-27 09:48:03 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.11.0'>]
23-10-27 09:48:03 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0
23-10-27 09:48:03 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-10-27 09:48:04 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-10-27 09:48:05 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
23-10-27 09:48:05 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
23-10-27 09:48:05 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-10-27 09:48:06 INFO (SyncWorker_1) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-10-27 09:48:06 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-10-27 09:48:06 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
23-10-27 09:48:06 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0
23-10-27 09:48:06 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-10-27 09:48:08 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-10-27 09:48:08 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
23-10-27 09:48:08 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
23-10-27 09:48:08 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-10-27 09:48:10 INFO (SyncWorker_1) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-10-27 09:48:10 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
23-10-27 09:48:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
23-10-27 09:48:10 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-10-27 09:48:11 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
23-10-27 09:48:11 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-10-27 09:48:26 WARNING (MainThread) [supervisor.utils.codenotary] Timeout while processing CodeNotary
23-10-27 09:48:26 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
23-10-27 09:48:26 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
23-10-27 09:48:26 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2023.06.0, updating
23-10-27 09:48:26 WARNING (MainThread) [supervisor.jobs] 'PluginCli.update' blocked from execution, supervisor needs to be updated first
23-10-27 09:48:26 ERROR (MainThread) [supervisor.plugins.manager] Can't update cli to 2023.06.0, the Supervisor healthy could be compromised!
23-10-27 09:48:26 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_UPDATE - ContextType.PLUGIN / cli
23-10-27 09:48:26 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.PLUGIN / cli
23-10-27 09:48:26 INFO (MainThread) [supervisor.plugins.manager] dns does not have the latest version 2023.06.2, updating
23-10-27 09:48:26 WARNING (MainThread) [supervisor.jobs] 'PluginDns.update' blocked from execution, supervisor needs to be updated first
23-10-27 09:48:26 ERROR (MainThread) [supervisor.plugins.manager] Can't update dns to 2023.06.2, the Supervisor healthy could be compromised!
