#rant
so here we go:
i’ve been working in IT for about 20 years , and i thought configuring HA Yellow would be a piece of cake
but oh boy what was i wrong , setting up the same with proxmox took me about 12 minutes, but HA yellow is , in my opinion a terrible product
The instructions are simple ;
1 construct device and insert usb with the software
1.result: nothing happens , everything keeps blinking , but never a finished install.
2 try option xyz
2.result , option x y and z are not working
try option pyboot with m2.ssd and usb cable
3.result finally i have a working HA -
configure for another network , setting the ip manually
4.result device never comes up again, need to resort to USB cable tty console
5.1 ip address works on current network, but switch to new network
5.1 result can’t get a new ip. , it refuses to DHCP
5.2 switching back to first network, and device is avaialble via web interface
5.2 setting the new ip manually is not succesfull , device cannotr be reached
5.3 trying to set ip in the CLI
5.3 result not possible because the contents of the cli are constantly overwritten with messages that BT is not working
disable BT
6.result Finally disabled BT via /mnt/boot/config.txt and the CLI is now quiet -
Change ip Manually with nmcli
7…result nmcli only spews gibberish via the tty console , can’t use any nmcli commands because i can’t even use the console decently
it only half of the time registers my input ,or simply refuses to respond. , sometimes the typed commands do work but are simply not shown on the screen , or i have to type a character20 times into the cli in order for it to grab… -
still tying to set ip. manually, and i hope i wil manage
but so far i’ve spent more then 10 hours to get this device to work, but I’m ready to throw it in the bin .
ps finaly got it to get dhcp, device reboots , and it won’t get the interface up
been at it for another hour … but it just refuses
i am done with this piece of crap for now, but if anyone can explain why this is such a terrible experience and costing a shitload of money for the hardware , i’m open to that
it shouldn’t be this hard should it?
ps2 the compute board is a pi 4 with 4 gb ram and 16gb ecc flash but i installed an m2 ssd on the board
