I have HA yellow and with 2MQTT with the below configuration
Zigbee2MQTT version
[1.37.1]
Coordinator type
EZSP v8
Coordinator revision
6.10.3.0 build 297
Frontend version
0.6.167
19.37.2
0.46.6
the issue is i was trying to update the driver from EZSP to Ember by editing the configuration to Ember and the MQTT is stooped working the the below error.
[2024-05-10 13:24:25] error: z2m: Exiting…
[2024-05-10 13:24:25] error: z2m: Error: NCP EZSP protocol version of 8 does not match Host version 13
at EmberAdapter.emberVersion (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1633:19)
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:784:9)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2642:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
so I think that i have to update the zigbee firmware. if yes how can i?
Thank you.
