bellows - permit:
bash-5.0# bellows -v DEBUG -d /dev/ttyUSB0 permit -D /config/zigbee.db
debug: Using selector: EpollSelector
debug: Loading application state from /config/zigbee.db
debug: Checking quirks for None None (00:0d:6f:00:0d:3b:10:82)
debug: Considering <class 'bellows.zigbee.application.EZSPCoordinator'>
debug: Found custom device replacement for 00:0d:6f:00:0d:3b:10:82: <class 'bellows.zigbee.application.EZSPCoordinator'>
debug: Resetting EZSP
debug: Initialize OTA providers
debug: Resetting ASH
debug: Sending: b'1ac038bc7e'
debug: OTA image directory '/config/zigpy_ota/' does not exist
debug: RSTACK Version: 2 Reason: RESET_SOFTWARE frame: b'c1020b0a527e'
debug: Send command version: (4,)
debug: Sending: b'004221a850ed2c7e'
debug: Data frame: b'0142a1a8502815eabd9d7e'
debug: Sending: b'8160597e'
debug: Application frame 0 (version) received: b'04020058'
debug: Sending: b'7d314321a85035937e'
debug: Data frame: b'1243a1a8502815eaf03d7e'
debug: Sending: b'82503a7e'
debug: Switched to EZSP protocol version 4
EZSP Stack Type: 2, Stack Version: 22528
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_STACK_PROFILE: 12>, 2)
debug: Sending: b'224021fb5828158cc87e'
debug: Data frame: b'2340a1fb54c6107e'
debug: Sending: b'83401b7e'
debug: Application frame 83 (setConfigurationValue) received: b'00'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_SECURITY_LEVEL: 13>, 5)
debug: Sending: b'334121fb592f15e8d57e'
debug: Data frame: b'3441a1fb54d32a7e'
debug: Sending: b'8430fc7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_SUPPORTED_NETWORKS: 45>, 1)
debug: Sending: b'444621fb792b15f7b37e'
debug: Data frame: b'4546a1fb5435d07e'
debug: Sending: b'8520dd7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS: 42>, 3)
debug: Sending: b'554721fb7d5e2915defb7e'
debug: Data frame: b'5647a1fb54a9ec7e'
debug: Sending: b'8610be7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD: 34>, 2)
debug: Sending: b'664421fb7628150b847e'
debug: Data frame: b'6744a1fb54948f7e'
debug: Sending: b'87009f7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE: 25>, 2)
debug: Sending: b'774521fb4d2815f46a7e'
debug: Data frame: b'7045a1fb5481b57e'
debug: Sending: b'8070787e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_ADDRESS_TABLE_SIZE: 5>, 16)
debug: Sending: b'004a21fb513a15ff5f7e'
debug: Data frame: b'014aa1fb54e28c7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_SOURCE_ROUTE_TABLE_SIZE: 26>, 8)
debug: Sending: b'7d314b21fb4e2215d06d7e'
debug: Data frame: b'124ba1fb547eb07e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_MAX_END_DEVICE_CHILDREN: 17>, 32)
debug: Sending: b'224821fb450a15e03c7e'
debug: Data frame: b'2348a1fb5443d37e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT: 18>, 7680)
debug: Sending: b'334921fb462a0b86cf7e'
debug: Data frame: b'3449a1fb5456e97e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_KEY_TABLE_SIZE: 30>, 1)
debug: Sending: b'444e21fb4a2b1566047e'
debug: Data frame: b'454ea1fb54b0137e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_TRANSIENT_KEY_TIMEOUT_S: 54>, 180)
debug: Sending: b'554f21fb629e1562217e'
debug: Data frame: b'564fa1fb542c2f7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT: 19>, 60)
debug: Sending: b'664c21fb471615d2c97e'
debug: Data frame: b'674ca1fb54114c7e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT_SHIFT: 27>, 8)
debug: Sending: b'774d21fb4f221578837e'
debug: Data frame: b'704da1fb5404767e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_MULTICAST_TABLE_SIZE: 6>, 16)
debug: Sending: b'005221fb523a15b1c97e'
debug: Data frame: b'0152a1fb547ce87e'
debug: Send command setConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>, 255)
debug: Sending: b'7d315321fb55d515fe6f7e'
debug: Data frame: b'1253a1fb54e0d47e'
debug: Send command getConfigurationValue: (<EzspConfigId.CONFIG_APS_UNICAST_MESSAGE_COUNT: 3>,)
debug: Sending: b'225021fa574fee7e'
debug: Data frame: b'2350a1fa54201586817e'
debug: Application frame 82 (getConfigurationValue) received: b'000a00'
debug: APS_UNICAST_MESSAGE_COUNT is set to 10
debug: Send command addEndpoint: (1, 260, 48879, 0, 0, 1, [], [1280])
debug: Sending: b'335121aa552e145de7944a24aa50e0797e'
debug: Data frame: b'3451a1aa54f5037e'
debug: Application frame 2 (addEndpoint) received: b'00'
debug: Ezsp adding endpoint: [<EzspStatus.SUCCESS: 0>]
debug: Send command setConcentrator: (False, <EmberConcentratorType.HIGH_RAM_CONCENTRATOR: 65529>, 600, 1800, 2, 5, 0)
debug: Sending: b'445621b854d3eaea5b9c4d27af5597827e'
debug: Data frame: b'4556a1b85476e87e'
debug: Application frame 16 (setConcentrator) received: b'00'
debug: Set concentrator type: [<EmberStatus.SUCCESS: 0>]
debug: Send command networkInit: ()
debug: Sending: b'555721bff5037e'
debug: Data frame: b'5657a5bf54af837e'
debug: Data frame: b'6657b1b1c49c787e'
debug: Application frame 23 (networkInit) received: b'00'
debug: Send command getNetworkParameters: ()
debug: Sending: b'67542180aa6e7e'
debug: Application frame 25 (stackStatusHandler) received: b'90'
debug: Data frame: b'7754a180542bc7faad03efb37908e75b944127abedce677302c16e677e'
debug: Application frame 40 (getNetworkParameters) received: b'0001d248f497a596d35d7512080f0000000000f8ff07'
debug: Send command setPolicy: (<EzspPolicyId.TC_KEY_REQUEST_POLICY: 5>, <EzspDecisionId.DENY_TC_KEY_REQUESTS: 80>)
debug: Sending: b'705521fd517a7f437e'
debug: Data frame: b'0055a1fd542d327e'
debug: Application frame 85 (setPolicy) received: b'00'
debug: Send command setPolicy: (<EzspPolicyId.APP_KEY_REQUEST_POLICY: 6>, <EzspDecisionId.ALLOW_APP_KEY_REQUESTS: 97>)
debug: Sending: b'015a21fd524b69a77e'
debug: Data frame: b'115aa1fd5457d77e'
debug: Send command setPolicy: (<EzspPolicyId.TRUST_CENTER_POLICY: 0>, <EzspDecisionId.ALLOW_PRECONFIGURED_KEY_JOINS: 1>)
debug: Sending: b'125b21fd542bd1927e'
debug: Data frame: b'225ba1fd54c35f7e'
debug: Send command getNodeId: ()
debug: Sending: b'2358218f8a8d7e'
debug: Data frame: b'3358a18f542a34997e'
debug: Application frame 39 (getNodeId) received: b'0000'
debug: Send command getEui64: ()
debug: Sending: b'3459218ee7167e'
debug: Data frame: b'4459a18ed63a2ebf59fb4725d6097e'
debug: Application frame 38 (getEui64) received: b'82103b0d006f0d00'
Device 0x0000 (00:0d:6f:00:0d:3b:10:82) joined the network
debug: Skip initialization for existing device 00:0d:6f:00:0d:3b:10:82
debug: EZSP nwk=0x0000, IEEE=00:0d:6f:00:0d:3b:10:82
debug: Send command getMulticastTableEntry: (0,)
debug: Starting EZSP watchdog
debug: Sending: b'455e21cb54957b7e'
debug: Data frame: b'555ea1cb542a15b294e67e'
debug: Application frame 99 (getMulticastTableEntry) received: b'00000000'
debug: MulticastTableEntry[0] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (1,)
debug: Sending: b'565f21cb5519667e'
debug: Data frame: b'665fa1cb542a15b2a22e7e'
debug: MulticastTableEntry[1] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (2,)
debug: Sending: b'675c21cb5614667e'
debug: Data frame: b'775ca1cb542a15b200cb7e'
debug: MulticastTableEntry[2] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (3,)
debug: Sending: b'705d21cb577d317d5d7e'
debug: Data frame: b'005da1cb542a15b2cfbe7e'
debug: MulticastTableEntry[3] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (4,)
debug: Sending: b'016221cb502e4a7e'
debug: Data frame: b'1162a1cb542a15b266bd7e'
debug: MulticastTableEntry[4] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (5,)
debug: Sending: b'126321cb51a2577e'
debug: Data frame: b'2263a1cb542a15b250757e'
debug: MulticastTableEntry[5] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (6,)
debug: Sending: b'236021cb52af577e'
debug: Data frame: b'3360a1cb542a15b2f2907e'
debug: MulticastTableEntry[6] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (7,)
debug: Sending: b'346121cb53aa4c7e'
debug: Data frame: b'4461a1cb542a15b23de57e'
debug: MulticastTableEntry[7] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (8,)
debug: Sending: b'456621cb5cbd597e'
debug: Data frame: b'5566a1cb542a15b25ec67e'
debug: MulticastTableEntry[8] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (9,)
debug: Sending: b'566721cb5d31447e'
debug: Data frame: b'6667a1cb542a15b2680e7e'
debug: MulticastTableEntry[9] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (10,)
debug: Sending: b'676421cb5e3c447e'
debug: Data frame: b'7764a1cb542a15b2caeb7e'
debug: MulticastTableEntry[10] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (11,)
debug: Sending: b'706521cb5f395f7e'
debug: Data frame: b'0065a1cb542a15b2059e7e'
debug: MulticastTableEntry[11] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (12,)
debug: Sending: b'016a21cb582a817e'
debug: Data frame: b'116aa1cb542a15b2f5107e'
debug: MulticastTableEntry[12] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (13,)
debug: Sending: b'126b21cb59a69c7e'
debug: Data frame: b'226ba1cb542a15b2c3d87e'
debug: MulticastTableEntry[13] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (14,)
debug: Sending: b'236821cb5aab9c7e'
debug: Data frame: b'3368a1cb542a15b2613d7e'
debug: MulticastTableEntry[14] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command getMulticastTableEntry: (15,)
debug: Sending: b'346921cb5bae877e'
debug: Data frame: b'4469a1cb542a15b2ae487e'
debug: MulticastTableEntry[15] = <EmberMulticastTableEntry multicastId=0x0000 endpoint=0 networkIndex=0>
debug: Send command sendBroadcast: (<BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR: 65532>, <EmberApsFrame profileId=0 clusterId=54 sourceEndpoint=0 destinationEndpoint=0 options=0 groupId=0 sequence=1>, 0, 2, b'\x01\x1e\x00')
debug: Sending: b'456e219ea8d515b26f944a25aa5592499d4e25a8ecd067f5047e'
debug: Data frame: b'556ea19e543a41697e'
debug: Data frame: b'656eb1ed512a158459944a25aa559259634e27ab1231648ae3c61d547e'
debug: Application frame 54 (sendBroadcast) received: b'0010'
debug: Application frame 69 (incomingMessageHandler) received: b'050000360000000000000010ff000000ffff03011e00'
debug: Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_BROADCAST_LOOPBACK: 5>, <EmberApsFrame profileId=0 clusterId=54 sourceEndpoint=0 destinationEndpoint=0 options=0 groupId=0 sequence=16>, 255, 0, 0x0000, 255, 255, b'\x01\x1e\x00']
debug: [0x0000:zdo] ZDO request 0x0036: [30, <Bool.false: 0>]
debug: Data frame: b'756eb19752d6eab259a24a25aa5592499c5e25cded50b77e'
debug: Application frame 63 (messageSentHandler) received: b'06fcff0000360000000000000010026600'
debug: Received messageSentHandler frame with [<EmberOutgoingMessageType.OUTGOING_BROADCAST: 6>, 65532, <EmberApsFrame profileId=0 clusterId=54 sourceEndpoint=0 destinationEndpoint=0 options=0 groupId=0 sequence=16>, 2, <EmberStatus.DELIVERY_FAILED: 102>, b'']
debug: Send command permitJoining: (30,)
debug: Sending: b'506f218a4a25297e'
debug: Data frame: b'066fa18a54353b7e'
debug: Application frame 34 (permitJoining) received: b'00'
Joins are permitted for the next 30s...
debug: Send command nop: ()
debug: Sending: b'616c21ad143c7e'
debug: Data frame: b'176ca1ad6a487e'
debug: Application frame 5 (nop) received: b''
debug: Sending: b'726d21ada3777e'
debug: Data frame: b'206da1ad20bc7e'
debug: Sending: b'037221adf8e47e'
debug: Data frame: b'3172a1ad22fd7e'
Done
debug: Data frame: b'4172b1ee54aaea63789582c855aa6db662b12be15ac86603eac66889f77e2ff92bdcde6fe0933ebfd7c11e377e'
debug: Data frame: b'5172b1ee54aaea787895822255aa6db662b12be15ac86603eac66889f77e2ff92bdcde6f0f2ef9ffd7c1f7bf7e'
debug: Data frame: b'6172b1ee54aaea7b7895822a55aa6db662b12be15ac86603eac66889f77e2ff92bdcde6f4b49ce69d7c12f2d7e'
debug: Data frame: b'7172b1ee54aaea7b7895823255aa6db662b12be15ac86603eac66889f77e2ff92bdcde6f0d07a461d7c1702c7e'
debug: Data frame: b'0172b1ee54aafa727895821855aa6db662b12be15ac86603eac66889f77e2ff92bdcde6ff70afd2cd7c1c82c7e'
debug: Data frame: b'1172b1ee54aaaf0c7895826155aa6db662b12be15ac86603eac66889f77e2ff92bdcde6f50b63df6d7c184ba7e'
debug: Data frame: b'2172b1ee54aaea777895827155aa6db662b12be15ac86603eac66889f77e2ff92bdcde6fb1a218dfd7c175667e'
debug: Data frame: b'3172b1ee54aaea7a7895829055aa6db662b12be15ac86603eac66889f77e2ff92bdcde6fc4b0fd1bd7c144f67e'
^C
Here I see one OTA image directory '/config/zigpy_ota/' does not exist warning, but don’t think this would be the problem.
Thanks again in advance for everybody!
