HA zigbee coordinator SLZB-06 break after update firmware
Yesterday, I updated the firmware version of the SLZB-06 coordinator and all the actuators/sensors are no longer working in Home Assistant.
In the Zigbee2mqtt log, the following message appears when I operate, for example, a switch:
error 2024-10-26 13:25:11`Publish
  • ‘set’ ‘state’ to ‘ChambreAmpli’ failed: 'Error: ZCL command *
    *0xa4c1380908f7bf10/1 genOnOff.on({}, *
    {“timeout”:10000,“disableResponse”:false,“disableRecovery”:false,“disableDefaultResponse”:false,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false})
  • failed (SREQ '–> AF - dataRequest - *
    {“dstaddr”:30371,“destendpoint”:1,“srcendpoint”:1,“clusterid”:6,“transid”:14,“options”:0,“radius”:30,“len”:3,“data”:{“type”:“Buffer”,“data”:[1,10,1]}}’
  • failed with status ‘(0x02: INVALID_PARAM)’ (expected '(0x00: *
    SUCCESS)‘))’`
Configuration :
  • Proxmox 8.2
  • Container LXC : Mqtt server 2.0.11
  • Container LXC : zigbeetomqtt 1.37.1
  • VM : HAOS 2024.10
  • SLZB-06
Fix IP for all.
Version SLZB-06 :
Thanks for your help
